Originally Posted by k_mridul
Is there any solution to this problem and to convert them back to [b]Win32 Programs?
Try this and see if it works...
First soln:
Try reinstalling the ms dos thing.
Goto start>run .In the open box type: "cmd".
at the comand promt, type in the follwing commands and press enter after each command:
expand CD-ROM drive letter:\i386\config.nt_C:\windows\system32\config. nt
expand CD-ROM drive letter:\i386\autoexec.nt_C:\windows\system32\autoe xec.nt
expand CD-ROM drive letter:\i386\command.com_C:\windows\system32\comma nd.com
Exit
Now try reinstalling.
Second soln:
If the above doesn't work...
In notepda type in:
dos=high,umb
device=%SYSTEMROOT%\system32\himen.sys
files=40
save the above with name "config.nt".
now again open a blank document and type the following entries:
@echo off
1h %SYSTEMROOT%\system32\mscdexnt.exe
1h %SYSTEMROOT%\system32\redir
1h %SYSTEMROOT%\system32\dosx
SET BLASTER=A220 I5 D1 P330 T3
save the file as "autoexec.nt".
Now locate the "config.nt" file and copy it to the %SYSTEMROOT%\system32 folder.
Do the same with autoexec.nt and command.com and restart...
Just try that and tell if it works.
