Old 23-08-2004, 01:42 AM   #1 (permalink)
Default HOW TO CONVERT DVD MOVIE INTO ANY OTHER FORMAT
HI I AM NEW USER HERE. ANYONE HELP ME HOW TO CONVERT DVD MOVIE INTO ANY OTHER FORMAT AND MAKE IT SMALL ENOUGH SO THAT I CAN BURN THEM IN A CD OR 2. PLEASE RECOMMENED A FREE SOFTWARE FOR IT AND ALSO WHERE I CAN DOWNLOAD THE SOFTWARE.
SINCERELY
NIRAJAN REGMI
"theregmi@yahoo.com"
nirajan is offline
Old 23-08-2004, 01:45 AM   #2 (permalink)
Download Gordian Knot!
As you enter this life,I pray you depart
With a wrinkled face,And a brand new heart.
-- U2\'s Love and Peace or Else (HTDAAB)
svenkat83 is offline
Old 23-08-2004, 12:55 PM   #3 (permalink)
http://www.afterdawn.com/guides/arch...anamorphic.cfm
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 23-08-2004, 12:57 PM   #4 (permalink)
Check that site out...there are plenty of articles there...Also you might wanna try this site:
www.dvdrhelp.com
loads of tutorials and articles there.
AMD 64 3500+ Venice
icecoolz is offline
Old 25-08-2004, 07:48 PM   #5 (permalink)
Default DVD to any other format
TO convert DVD format .VOD to any file.
use the best convertor "KONVERTOR" not only DVD files but pictures,audio,video and text files...........search and download onlne...
if u can't find ------greyblue86@yahoo.co.in------
Computer,music and games are great entertainments
greyblue is offline
Old 25-08-2004, 08:39 PM   #6 (permalink)
can use Dr. divx too.. or autogk.. for simpler use...
I\'M BACK
khandu is offline
Old 28-08-2004, 07:25 PM   #7 (permalink)
well ,
dr. DivX is good but you will have to buy a legitimate copy becase its very hard to get Dr. divX if you are looking for pirated one
in other way you can use Dvd Easy and Virtual Dub
free and very good
Killer_Sam is offline
Old 28-08-2004, 11:34 PM   #8 (permalink)
Not So Fresh Stock!
Go to Doom9:
http://www.doom9.org/software2.htm
Download VirtualDub.
It will do your job perfectly. But a little help is what you may need. So go to
http://www.doom9.org/virtualdub_procedures.htm
And if you need more help. Post here. There are plenty people to help you out.
http://krishanu.in
Krishanu.De is offline
Old 29-08-2004, 07:00 PM   #9 (permalink)
gordian knot from doom9.org has a nice bunch of softwares for this and also the required codecs. download the two bundles. they are around 10mb in size.
A program is a device used to convert data into error messages.
samrat_chak1 is offline
Old 13-09-2004, 09:53 PM   #10 (permalink)
sandeep8000861's Avatar
Yeah look out for Updates too. Latest codecs r always Better.
sandeep8000861 is offline
Old 14-09-2004, 06:48 AM   #11 (permalink)
144
144's Avatar
Default DVD Rip N`Burn
Hi Niranjan,
DVD Rip N` Burn is an easy to use small software which is FREE.
Try it.
Its easy to use. Plus it is a small file. (7.2MB)
you can download the file at the follwing url:
Link:http://www.dvdripnburn.com/
*you will need macromedia flashplayer to view this site.
cheers,
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
- by Piyush
