Old 04-04-2005, 11:29 PM   #1 (permalink)
Default receiving! file problem!!
hi,
People i'm suffering from a strange problem like I cant receive files on my messenger ..... i'm sick of this problem i have tried a lot! but the same problem prevails!
Plzz tell me wat can i do ? I'm on XP SP2, Pc-cillin 2004, Ad-aware! ..
& forgot to mention earlier i was receiving! & sending files successfully! my main problem is I cant receive files.. my seetings R correct in messenger!!
plzz help me! mates!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 04-04-2005, 11:35 PM   #2 (permalink)
It may be the firewall blocking the communication. Try disabling the firewall and then receive the file.
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
Old 05-04-2005, 10:04 PM   #3 (permalink)
no! firewalls as such! ... i told U it was happening sometime before perfectly ... i'm not able to send & receive files on messenger ...
Old 05-04-2005, 10:39 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
I THINK ITS WINDOWS FIREWALL
Choto Cheeta is offline
Old 06-04-2005, 08:03 AM   #5 (permalink)
rajesh's Avatar
Yup. It is the firewall. I also had similar problems and disabled the firewall.
My Blogs
______________________
http://laughlines.rediffblogs.com
http://krrajesh.blogspot.com
rajesh is offline
- by Piyush
