Old 04-04-2005, 10:19 PM   #1 (permalink)
Default Deep Trouble
Hi guys,
I'm in deep trouble guys. I got an error message :-
C:\WINDOWS\SYSTEM32\AUTOEXEC.nt ... something like that when I try to run the Adobe After Effects shareware given in this Month's Digit DVD. I checked last month's issue. I found some solutions in QUESTION OF THE MONTH. I tried all of the solutions. After trying the Notepad Solution, When I try to open any setup Executable file, then MS-DOS appears and a message also appears telling that "This file is too big to be run" in DOS. Plz help me. And there is also a mistake in the answer of the question. They say to do the same with command.com ... but nothin is told about command.com . Plz help me guys ... My brother is toooooooooo much angrty at me . and i want this to be solved by tommorow
Your mouse has moved ... Windows needs to reboot for the changes to take effect :)
Next_Big_thing is offline
Old 04-04-2005, 11:34 PM   #2 (permalink)
mekalodu
iinfi's Avatar
i dunno the exact solution .... googled and this is what i found
http://www.iamnotageek.com/a/413-p1.php
http://forum.theispguide.com/isp-ftopic2830.html
hope this helps ....
mekalodu
iinfi is online now
Old 05-04-2005, 10:54 AM   #3 (permalink)
Thanks a lot. It helped me a lloooooot!!!
Old 05-04-2005, 05:04 PM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Try this page ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
- by Piyush
