Old 27-01-2008, 12:19 AM   #1 (permalink)
NP : Crysis
xbonez's Avatar
Default lyrics plugin for WMP 11 reqd
guys, i need a plugin for WMP 11 that shows lyrics of the song Now Playing and more importantly, saves it to the ID3 tag of the song
xbonez is offline
Old 27-01-2008, 12:55 AM   #2 (permalink)
MMO Addict
amitava82's Avatar
Default Re: lyrics plugin for WMP 11 reqd
Do you mean show existing lyrics in the file? If yes then enable it by: R-Click on top bar/menu > Play > Lyrics, captions... On if available.
You can use a software called TagRunner which automatically fetch lyrics, albumart etc from net and save it inside the mp3 file.
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 27-01-2008, 01:27 AM   #3 (permalink)
NP : Crysis
xbonez's Avatar
i need a plugin to fetch the lyrics n save to tag....currently i use lyrics plugin...it works really well,is quite fast but doesn't save to tag
xbonez is offline
Old 27-01-2008, 01:45 AM   #4 (permalink)
MMO Addict
amitava82's Avatar
Then use TagRunner. Its the best. Add all your songs in the list, run and forget it.
Old 27-01-2008, 02:06 AM   #5 (permalink)
NP : Crysis
xbonez's Avatar
k, thnx...lemme try it
xbonez is offline
Old 28-01-2008, 07:48 PM   #6 (permalink)
Mad and Furious
redhat's Avatar
Guys, I need a plugin for WMP11, to sync lyrics with time and save the sync'd lyrics as an lrc file.
I know, WMP11, also allows for sync lyrics, but the interface is very bad, I once had 1 such plugin for Winamp. In that, I onli had to click on a line of d lyrics while d song was playing and it would sync that line with the time u clicked at. Any such plugin for WMP?
redhat is offline
Old 28-01-2008, 11:44 PM   #7 (permalink)
NP : Crysis
xbonez's Avatar
sorry forgot to follow up...i dl'ed TagRunner from a torrent...got excellent speeds....21 seeds 0 peers...i fired it up...added my entire song collection of about 2500 songs (~12gb)...out of the 2500, it added lyrics to about 2100 of them in 1hr 10min...thats quite a gud hit rate...most of the failed ones were also my fault since they weren'tt agged properly...
bottomline : awesome s/w that solved my prob
PS - my dl'ing TagRunner from a torrent has absolutely nothing to do with it being a paid software, i swear ... i merely wanted to conserve the compan'y bandwidth
xbonez is offline
lyrics nameless QnA (read only) 2 04-01-2008 05:42 PM
Lyrics in mp11 bukaida QnA (read only) 1 09-07-2007 12:57 PM
adding lyrics with song NIGHTMARE Software Q&A 18 07-05-2007 09:04 AM
lyrics site valtea Open Source 6 01-03-2006 11:52 AM
ADD LYRICS TO MP3'S IN WINAMP????? tango_cash Software Q&A 3 23-06-2005 10:50 PM
- by Piyush
