Old 22-08-2004, 08:31 PM   #1 (permalink)
Default (COMPRESSOR) DAT TO AVI
I have recently installed River Past video cleaner for converting
movie files (.dat files) into AVI files.
There are lot of video compressors like DivX5.1.1 Codec, MJPEG Compressor and lot of audio compressors like Microsoft ADPCM, WM Speech Encoder DMO.
Please tell me which audio and video compressor to use to so that the movie files are compressed to the maximum extent.
I am using windows XP(SP1) having 128MB of RAM.
Someone is always observing you who is capable of greatly blessing you.
It\'s a truism that our worst affected wounds are self inflicted
Just Another F*$%/ed up day in Paradise
SHell is offline
Old 22-08-2004, 09:50 PM   #2 (permalink)
Use Xvid with Lame mp3 @ 128 Kbps in joint stereo mode. Use a resolution like 592x320, 576x240 at 23/25 FPS and bit rate of arnd 700-750Kbps which will give you the desired results.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 23-08-2004, 12:26 AM   #3 (permalink)
Not So Fresh Stock!
But use VirtualDub for the compression. If you are looking for a click & go type software for compression then go for Dr. DivX although it is not free. But I guess that will not be a problem for you.
http://krishanu.in
Krishanu.De is offline
Old 23-08-2004, 12:49 PM   #4 (permalink)
use Dr.DivX. download it from divx.com
prankzter is offline
Old 23-08-2004, 01:31 PM   #5 (permalink)
AskRajesh
rajeshjsl's Avatar
use virtualdub
rajeshjsl is offline
Old 23-08-2004, 04:49 PM   #6 (permalink)
Shell r u asking abt the software or the codec ?
Old 23-08-2004, 06:14 PM   #7 (permalink)
Dr. DivX , its simple, easy 2 use and does the job neatly
Walk on the Wild Side. The other side SUX!!!
krazydude is offline
Old 23-08-2004, 11:51 PM   #8 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
VirtualDub Mod .. and try Matrox Compression ..
http://virtualdubmod.sourceforge.net/
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 23-08-2004, 11:54 PM   #9 (permalink)
And XVid .. Its a free open source alternative to DivX ..
http://www.xvid.org/
http://www.doom9.org/xvid.htm
Old 24-08-2004, 05:40 AM   #10 (permalink)
Not So Fresh Stock!
But for the XVID binary you have to look somewhere else than there official website. They have the source not the binary. Optionally you can compile your own binary.
For the binary from doom9 you can go here:
http://www.doom9.org/Soft21/Codecs/X...1-05062004.exe
Old 24-08-2004, 01:18 PM   #11 (permalink)
i think virtualdub is good Dr. DIVX is also nice
Music is like Sex, The more you get, the more you want.
demoninside is offline
