Old 04-04-2005, 02:04 PM   #1 (permalink)
Default Formattig Blues
I want to format my C Drive which has Windows XP installed in it.It reads the XP Bootable Cd when I run it simply but if I try to boot using the bootable CD it never detects itb (have changed the bios settings -all booting devices to CD)
sourcecode is offline
Old 04-04-2005, 03:33 PM   #2 (permalink)
Default First
First of all in the bios the primary boot device should be the cd drive.first check that and try again.If its not working why dont u try out the cd in ur friends pc.Might be something wrong with the cd
vasanth_12345 is offline
Old 04-04-2005, 04:30 PM   #3 (permalink)
If u want to perform a clean install , u could run the win xp setup within xp .perform an advanced installation.then while installing ,xp asks which drive to install and whether to format or not.u culd make ur choice then.
and get ur cd checked - it may / not be bootable.
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 04-04-2005, 04:41 PM   #4 (permalink)
ferrarif50's Avatar
Are u sure u r using the original WinXP CD? if not, it may not boot. Anyways, in any case, u can install Windows even if the CD does not boot.
Use a boot floppy disk to go to the command prompt. Access ur Windows XP CD, and change to the i386 folder. Now run WINNT.exe to install!
My time machine will take you one hour into the future in only sixty minutes!
ferrarif50 is offline
