hi guys!
i was just trying an old trick of adding CLSID at the end of the folder Name......and accidentally i added this
Windows Security - {2559A1F2−21D7−11D4−BDAF−00C04F60B9F0}
Now the problem is i cannot rename the folder using
ren command in command prompt.
it gives message "system cannot find specified file".(while i can easily see the folder with
dir command).....
i also tried making a batch file for this but while saving it says that it contains hex value and if saved in ANSI form, data will be lost. for that i saved the file in Unicode, and still it doesn't work.....
i can see the file with the extension {CLSID} through winRAR.....but cannot rename it.............
pls help!!
