Old 04-04-2005, 11:29 AM   #1 (permalink)
Default FTP through Proxy
Hi ppl there,
How to upload the files to our site using the SmartFTP. I am unable to connect to the server the error message is below. Please help.
OS - WinXP with SP2
SmartFTP settings: Tools --> Settings --> Connection --> Proxy --> Type: None
SmartFTP v1.1.985.2
Resolving host name 202.65.143.64...
Connecting to (202.65.143.64) -> IP: 202.65.143.64 PORT: 21
Connected to (202.65.143.64) -> Time = 0ms
Socket connected waiting for login sequence.
Connection timeout. No response from server.
Cannot login waiting to retry (30s)...
When I changed the proxy setting to
SmartFTP settings: Tools --> Settings --> Connection --> Proxy --> Type: HTTP Proxy - Connection Tunnel
SmartFTP v1.1.985.2
Resolving host name 10.2.2.212...
Connecting to Proxy (10.2.2.212) -> IP: 10.2.2.212 PORT: 21
Connected to Proxy (10.2.2.212) -> Time = 0ms
220 cascm Microsoft FTP Service (Version 5.0).
And there are more types are there which type i have to use, the other types are SITE Hostname, OPEN hostname, USER user@host, USER user@host:port, SOCKs 5, SOCKs 4, SOCKs 4A, User@Host FireID, USER User@FireIDHost, USER user@Host FireID, HTTP Proxy - Connection Tunnel
Thanks.
mahender is offline
Old 04-04-2005, 11:40 AM   #2 (permalink)
Dude make sure you input the username & password required for that ftp site.
As far as I can see it there is nothing to do with a proxy.
When I connected through a ftp client & also from the browser I got a message to input the username & password to access the ftp page.
www.Oobertech.net
digen is offline
Old 04-04-2005, 12:24 PM   #3 (permalink)
I have given u/n and p/w correctly. Even then I am unable to connect to.
mahender is offline
Old 04-04-2005, 12:55 PM   #4 (permalink)
I was just testing it with a anonymous login,it went pretty well upto the username & password authentication.Anonymous logins have been disabled on the server so I couldnt connect,in case if its possible for you then pm me the username password of the ftp site.
By any chance are you behind a firewall?
www.Oobertech.net
digen is offline
Old 04-04-2005, 01:37 PM   #5 (permalink)
Yes I think we are behind firewall. Actually are on a state wide Wide Area Network (WAN) and it is a leased line taken by the Govt. of AP. Our web site is hosted at Pioneer Online situated at Hyderabad. Peviously we used to upload our website files through dial-up connection. With dial-up it worked fine. But when are trying with our WAN connection then we are facing with this problem same with the Outlook Express also. We are unable to connect to through this WAN connection.
We are able to browse the net without any problems.
mahender is offline
Old 04-04-2005, 04:58 PM   #6 (permalink)
Well if he was behind a restricted firewall then he wouldnt have got a 503 error he would have gotten a 403 error access forbidden. So I guess u can ftp but the problem seems to rest on your ftp server which is asking for authentication. Check your ftp server and make sure all the passwords are proper. Also try and see if you can ftp to other sites and see if that works.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 04-04-2005, 05:30 PM   #7 (permalink)
Hi,
Just wanted to know what kind of proxy software is being used. Many of the light-weight free ones do a terrible job as far as giving FTP access is concerned. Is FTP access turned "on" in the proxy server?
I am not sure if SmartFTP supports passive mode (or whether the server does the same). Please try turning on the option in Smart FTP if it is there.
DH
Where is the wisdom we have lost in knowledge?
Where is the knowledge we have lost in information? - (Choruses from the rock - T.S. Eliot)
Doc Holliday is offline
Old 05-04-2005, 12:29 AM   #8 (permalink)
Naa ice actually I wasnt thinking w.r.t a firewall blocking outbound connection but instead the active mode of the ftp server which could be blocked by the firewall itself.
But since they could access it using dial-up that rules out the possibility,but it would be worth checking.
www.Oobertech.net
digen is offline
Old 06-04-2005, 10:16 AM   #9 (permalink)
whoopy_whale's Avatar
Let me suggest a simple way.
Visit Surftp.com.
It's an online ftp service.
You can
Navigate the FTP server
Upload files
Download files
Zip files
Copy, move and delete
Copy files to a 2nd FTP server
and more...Try it..
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 06-04-2005, 01:22 PM   #10 (permalink)
Thanks a lot guys. surftp.com is very good. But is it safe to use. However, my actual problems still exists. Any help.
mahender is offline
Old 06-04-2005, 01:56 PM   #11 (permalink)
mahnder, so do we understand from this that you CAN ftp to other sites ? If so then it is your ftp server issue. If it is an internal proxy then try ftp from the command prompt and see if that works. If not then the ftp is the issue. See if you can setup a user/pass and access the site.
AMD 64 3500+ Venice
icecoolz is offline
Old 06-04-2005, 03:04 PM   #12 (permalink)
ftp server is not located at our place. It is in our State Headquarters.
What do you mean by
can you elaborate
because I already have a username and password.
mahender is offline
