Old 21-01-2008, 07:29 AM   #1 (permalink)
High without substance...
chicha's Avatar
Default HDD drives detected as removable drives
My friend faces this problem(he calls it problem as he is fed up with it), He has a 160GB SATA segate HDD. every time he boots his pc, his hdd is detected as removable drives and all his drives are then detected individually.
why?
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
Old 21-01-2008, 07:57 AM   #2 (permalink)
=--=l33t=--=
ring_wraith's Avatar
Default Re: HDD drives detected as removable drives
I think that's coz SATA is hot-swappable.
Homer: God bless those pagans.
ring_wraith is offline
Old 21-01-2008, 09:48 AM   #3 (permalink)
chicha's Avatar
But i have SATA too and it does not happen to me.
and what exactly do you mean by hot-swappable?
i am confused. can we dissconnect the HDD while the system is running?
chicha is offline
Old 21-01-2008, 10:28 AM   #4 (permalink)
motobuntu's Avatar
I guess b'coz u might have installed your OS on that same disk and due to that u'r drive is not showing as removable disk.
Yes, you are right about the hot-swappable thing.
A computer once beat me at chess, but it was no match for me at kick boxing.
motobuntu is offline
Old 21-01-2008, 04:12 PM   #5 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
do check BIOS ......
... W H O T ...
ax3 is offline
Old 21-01-2008, 07:17 PM   #6 (permalink)
chicha's Avatar
ok thank you.
chicha is offline
Old 22-01-2008, 01:55 PM   #7 (permalink)
that is becoz only some motherboards provide the facility of hot swappable sata HDD. i.e. you can add/remove a non OS hdd. the motherboards that provide this facility show the drives as removable hdds.
manmay is offline
CD-Rom drives not detected abhishek_del QnA (read only) 24 17-07-2007 07:38 AM
kernel-2.6.19 onwards CD/DVD IDE drives are detected as SCSI/SATA like /dev/scd0 freebird Open Source 13 13-04-2007 07:29 PM
CD Drives not detected ..seems a little weird praka123 Open Source 11 11-08-2006 07:26 AM
Changing removable drvie icons,for each drives ..please help eureca_eureca Software Q&A 4 26-10-2005 10:37 PM
Digit's DVD drives the market's drives shakshy QnA (read only) 3 30-10-2004 09:27 PM
