Old 20-01-2008, 10:07 PM   #1 (permalink)
SivaChand
Default How to remove manually
My friend's system affected by virus. I found there were duplication of system process(1.csrss.exe 2.winlogon.exe 3.services.exe 4.lsass.exe 5.smss.exe) and also i found these .exe are located in the (C:\Documents and Settings\Ramesh\Local Settings\Application Data). When i try to open that location the system going to restrat and not even to install new things.... When i try to run the script also its going to restart.... What to do now? Any suggestions?
Always look at what you have left.Never look at what you have lost
kpmsivachand is offline
Old 20-01-2008, 10:08 PM   #2 (permalink)
CG Artist
gaurav_indian's Avatar
Default Re: How to remove manually
Try to remove those in safe mode.
gaurav_indian is offline
Old 20-01-2008, 10:14 PM   #3 (permalink)
SivaChand
Thxs for quick reply.... I tried in the safemode and wrote the script for deleting these files... But won't work... Any other suggestions???
Old 20-01-2008, 10:45 PM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
Try to scan with a good antivirus & antispyware, in safe mode.
Blogging at:
Technostarry
saqib_khan is offline
Old 20-01-2008, 10:49 PM   #5 (permalink)
SivaChand
if I try install new things it become restart
Old 21-01-2008, 11:45 AM   #6 (permalink)
adi007's Avatar
Try ending the process using processxp..
http://technet.microsoft.com/en-us/s.../bb896653.aspx
^^It's a freeware
Now if ends the process remove the startup entries of these file by using msconfig
run--> msconfig
some times these will exhibit as services so make sure to remove these services from msconfig...
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline
Old 21-01-2008, 09:44 PM   #7 (permalink)
SivaChand
Thank you dude
Old 22-01-2008, 10:44 AM   #8 (permalink)
adi007's Avatar
^^Did it worked...
adi007 is offline
Old 22-01-2008, 02:59 PM   #9 (permalink)
TechTin.com
ravi_9793's Avatar
@adi007 has given you good link.
You can also use unlocker to find what programs are using that file.
ravi_9793 is offline
Old 22-01-2008, 08:54 PM   #10 (permalink)
SivaChand
Cool Re: How to remove manually
Originally Posted by adi007 View Post
^^Did it worked...
Tomorrow only i am going to check it with my friend system.... Thanks for the link....
Manually setting Grub splash? Dark Star Open Source 8 03-11-2007 03:02 PM
Switch of the LCD moitor manually or let it sleep. I Do Not Have A Username. TVs / Monitors 2 29-11-2006 08:47 PM
How to change the MAC Address of NIC card manually? Mahesh Babu QnA (read only) 9 10-07-2005 05:15 AM
Downloaded files manually not working.. Charley Internet & WWW 1 16-02-2005 02:19 PM
