Old 19-01-2008, 09:16 PM   #1 (permalink)
Default What is AA (Anti Aliasing)
Yup that's right. I just basically know what AA does :
  • Smooths edges
  • Improves Image quality
  • Screws FPS
But i don't think i know much about it. Could anyone explain it to me in detail ?
One more question -
What AA level (2x/4x/8x) and AF level (8x/16x)will be sufficient for a 1024x768 resolution gaming at high settings for best Image quality? In such scenarios will the game performance be dependent on my GPU or CPU?
°K£l†huzaD° is offline
Old 04-02-2008, 01:19 AM   #2 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Re: What is AA (Anti Aliasing)
http://en.wikipedia.org/wiki/Antialiasing
Hope it helps.
4x AA is supposed to be good for a 1024x768 resolution screen, but as you have a 15" TFT, I suppose 2x may be suffitient.
The game performance in these situations will depend on the GPU usually, but its *possible* to use the CPU to boost things up, if your i865 mobo's onboard graphics chip can't handle things well. I heard of some hacks to do this, but I can't give much information about the same.
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 04-02-2008, 02:03 AM   #3 (permalink)
dOm1naTOr's Avatar
8Xs has the same load as 4X nd have better image quality.
And if u use higher resolutions on a relatively small monitor, then AA is not that needed. Like on a 17" CRT playing @ 1280*1024 dun need AA much. 2X wud do fine.
But if u play @ 800*600 on a 17" CRT, then at least 4x or 8xs shud be set for gud quality.
In games like Crysis, even higher AA setings shows bit of small jaggies. So it also depends on game engine.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 04-02-2008, 02:07 AM   #4 (permalink)
The Smaller Bang
relatively small monitor ? This guy has a 15" Samsung TFT Supporting a maximum of 1024x728 resolution. I don't think AA is even needed here. Still, for 800x600 and 640x480 games(if they exist today) and games like ragnarok, I suppose 2x will do.
Old 04-02-2008, 06:53 AM   #5 (permalink)
dOm1naTOr's Avatar
He hasnt mentioned his monitor nd gcard. Nd how did u know that?
G3: XPS M1530 |
FZ 16.
Old 04-02-2008, 10:09 AM   #6 (permalink)
The Smaller Bang
He is my friend.
Anti-aliasing and Anisotropic filtering explained shady_inc Gamerz 5 22-08-2007 08:42 PM
Problem with anti-aliasing Stalker Gamerz 2 03-09-2006 04:19 PM
Top 10 Anti-Virus and Anti-Spyware of 2006 hcp006sl Software Q&A 12 13-07-2006 11:59 AM
Ip aliasing in win xp (networking guys .. look in ) Ricky Software Q&A 8 14-05-2006 11:30 PM
