Old 17-01-2008, 09:55 AM   #1 (permalink)
Default Restore temp files - URGENT HELP REQD
Hi friends,
I was working on a very important file, which i had opened as an attachment from Outlook. After working, i closed the file and the command asked if i wanted to save. I think the folder it got saved in was 'OLK13B' in temporary internet files folder.
When i try to find this folder, i cannot and hence cannot trace the file i was working upon.
Can somebody help me restore this file and how can i do the same?
Thanks
Gurpreet
er_gurpreet is offline
Old 17-01-2008, 12:42 PM   #2 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Re: Restore temp files - URGENT HELP REQD
copy that file 2 some other folder ....... r-click & click open with Outlook ....
hope it works ......
... W H O T ...
ax3 is offline
Old 17-01-2008, 01:18 PM   #3 (permalink)
Thanks. It did work.
Old 17-01-2008, 04:42 PM   #4 (permalink)
ax3
ax3's Avatar
Wal - Com ............
... W H O T ...
ax3 is offline
help temp internet files are taken 1.7 gb !!! abhasbajpai Internet & WWW 4 27-06-2006 08:54 PM
CPU Temp. Woes Urgent............ navjotjsingh CPU / Motherboards 20 24-04-2005 11:43 PM
Urgent Sugestions reqd. speedyguy QnA (read only) 11 21-02-2005 01:46 PM
URGENT HELP REQD........ liquid_nitrogen88 QnA (read only) 6 20-12-2004 09:55 PM
