Satissh_s wrote
you know ashu i always use sony cd's for writing data...... and yet i get this error in the fedora core linux installation cd 3.,
oe3openoffice traditional chinese not found
contine quit something like that!!!!!!
Well Buddy ! hv u burned or copied the software onto a blank SONY cd from the original one !!
if yes then there can be a loss of data while burning ur cd if there r other activities goin on in ur PC like ANITVIRUS running in backgroung, screen saver running or any other activities like wen u r connected to the net and a firewall is running.
well the safest thing to do is that while u r burning the Cds, close any programs running on ur PC like Wallpapers, screen savers, antivirus programs, firewall and offline from net.
Coz there has been a loss of data while these programs r running, so wen the burning is in progress plz do not do any other thing on PC jus for safety, coz after all ur data burning is more important RITE !! neways just post ur results here if u hv any other problems....
cheers n peace.....
