Old 16-01-2008, 11:13 PM   #1 (permalink)
Be Healthy, Keep Smiling
Kaushal Hiwarkar's Avatar
Default What is Remote desktop login
Hello friends
I have a 2 system connected on Lan with broad band connection.
I use computer1 ,I want to know that can I use computer2 wihtout siting on that computer. (just by stting on comp1 ). I can operate computer2 from computer, Is it possible, If yes then plz tell me the procedure. I also want to know about Remote Desktop Login
Kaushal Hiwarkar is offline
Old 17-01-2008, 12:01 AM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: What is Remote desktop login
check this tutorial Sharing desktop remotely using real VNC
Charan is offline
Old 17-01-2008, 10:55 PM   #3 (permalink)
I have gone through ur tutorial. Really it was nice Thank u, But I have some doubts.
I have successfully tried this, but will it be used in context to Internet also.
I mean to say that can i get control on my friend system which is not connected to LAN.. We both use internet can I log in his computer using ur s/w.
One more doubt can I hide this program (VNC server)so that no one knows that VNC is running or not, and I VNC viewer get control on server, if yes plz tell me
Old 17-01-2008, 11:50 PM   #4 (permalink)
Rubik's Uncle!!
Charan's Avatar
^^ yes its possible to use VNC over internet if you know the IP address of your friends system.
2. AFAIK you cannot hide the icon because it will cause a security risk. when ever a VNC session is connected the icon will change to black indicating that the system is controlled remotely.
Charan is offline
Old 18-01-2008, 11:17 PM   #5 (permalink)
thnks Bro
Remote desktop spp_itim Software Q&A 9 20-12-2007 11:53 AM
Remote Desktop kushals QnA (read only) 5 19-07-2007 01:40 PM
how 2 get remote desktop snlmohanty QnA (read only) 1 18-05-2006 02:03 PM
Remote Desktop godsownman QnA (read only) 5 08-04-2006 10:39 PM
remote assistance or remote desktop ? mkmkmk QnA (read only) 7 10-03-2006 09:35 PM
