Old 16-01-2008, 07:17 PM   #1 (permalink)
vaibhavtek
Posts: n/a
Question AVI to DIVX
Can anyone one suggest me a software that can convert avi to divx without reducing quality..???
Plz reply ASAP.
Old 16-01-2008, 08:22 PM   #2 (permalink)
Techtree Reviewer
krazzy's Avatar
Default Re: AVI to DIVX
LOL! As far as I know avi is a container format and divx is one of the codecs it contains (please correct me if i'm wrong). So you can't convert avi to divx because they're kinda same.
krazzy is offline
Old 16-01-2008, 08:29 PM   #3 (permalink)
vaibhavtek
Posts: n/a
^^ lol u are wrong i just used a program to convert but it decrease quality so i had posted here.
Old 16-01-2008, 08:47 PM   #4 (permalink)
-----ATi-----
nvidia's Avatar
See if you can set the quality in your program.. There must be some option somewhere.....
http://twitter.com/akshayms
nvidia is offline
Old 16-01-2008, 09:00 PM   #5 (permalink)
SivaChand
These softwares are not freeware...
kpmsivachand is offline
Old 16-01-2008, 09:15 PM   #6 (permalink)
vaibhavtek
Posts: n/a
@nvidia8800
no option
@kpmsivachand
i know
Old 17-01-2008, 03:04 PM   #7 (permalink)
vaibhavtek
Posts: n/a
bump
Old 17-01-2008, 03:14 PM   #8 (permalink)
Elevating Humanity
The Conqueror's Avatar
http://www.divx.com/divx/windows/converter/
Convert nearly any video to a DivX® video by simply dragging and dropping it onto the DivX Converter.
Hope this will help
Regards,
The Conqueror
The Conqueror is offline
Old 18-01-2008, 02:35 PM   #9 (permalink)
vaibhavtek
Posts: n/a
^^ i used Fraps and SnagIt for recording video.
And when i try to convert it i got an error
Anybody plz help.
Old 18-01-2008, 06:41 PM   #10 (permalink)
vaibhavtek
Posts: n/a
bump
Old 18-01-2008, 09:33 PM   #11 (permalink)
vaibhavtek
Posts: n/a
again bumped
Old 18-01-2008, 09:36 PM   #12 (permalink)
Stay Silent!
enticer86's Avatar
Originally Posted by vaibhavtek View Post
bump
bump
again bumped
O Bhai... dekh ke chalaya karo.
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
enticer86 is offline
Old 18-01-2008, 09:38 PM   #13 (permalink)
vaibhavtek
Posts: n/a
he he
plz help.
Old 18-01-2008, 10:20 PM   #14 (permalink)
99.9% Idle
axxo's Avatar
Let me give my possible solution...
1. Capture softwares does use their codecs which sometime not be detected outside players...if you use fraps make sure FPS1 codec
and for snagit TSCC & ensharpen codec be installed & working properly
2.Divx6 places restrictions on the video resolution for many of its profiles and this may cause an error when handling large Fraps videos. I suppose your captured video might use one such resolution and hence the error
In Virtualdub you can go to the Divx codec configuration screen and set it to use the "Unconstrained Profile". This will allow you to encode movies of any resolution and won't generate the source format error.
axxo is offline
Old 19-01-2008, 09:42 AM   #15 (permalink)
vaibhavtek
Posts: n/a
I cannot understand what u mean...!!!
Can u just write a tutorial upon how to make video from fraps and convert the same with DivX6.
Plz reply me ASAP..
Plz help
Old 19-01-2008, 12:15 PM   #16 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
to avoid reduction in quality, there is only one way: transmux instead of trasnscode. But the divx container is just a hack of the avi container, so you need not convert anything as there will be no gain in quality. Lossless convertion is not possible unless you use a newer version of the video codec with an upgrade option(like using theora on VP3 video).
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 19-01-2008, 07:27 PM   #17 (permalink)
99.9% Idle
axxo's Avatar
Plz reply me ASAP..
Plz help
am too noob to write a tutorial..
capture game video of your preffered setting..
my setting is as follows
I captured the game video @ 1024x768 resolution
download virtualdub mpeg2 - > link
extract to a folder & run virtualdub.exe
open captured video file from file->open video file
customize the settings as shown..i prefer no audio..
then finally click file->save as avi->name your video & save..
done...
converted my 344 MB file to 3 MB divx file.
sample video download
axxo is offline
Old 21-01-2008, 02:16 PM   #18 (permalink)
vaibhavtek
Posts: n/a
thanks buddy very very much.
Old 21-01-2008, 05:53 PM   #19 (permalink)
99.9% Idle
axxo's Avatar
^ glad that it works for u
axxo is offline
How to burn divx/xvid files to dvd to play in Divx player? casual_gamer Software Q&A 8 01-08-2007 09:49 AM
Burning speed for DivX movies to view on a DivX player webgenius Software Q&A 2 04-02-2007 08:52 PM
divx dvd help... santu_29 QnA (read only) 3 05-01-2007 02:51 PM
which format does divx players support *.divx or *.avi or both? kotha81 Software Q&A 2 23-10-2006 08:29 PM
divx and usb gambit Peripherals 6 08-01-2005 08:32 PM
