Old 15-01-2008, 04:34 PM   #1 (permalink)
Default Image editor Needed , help for starting a web page too
Guys i need an image editor that can reduce the size of image under a fixed size
i am planning to start a web page for wallpapers ..the images are around 6 Mbs in size , so i need to reduce the images to save bandwidth.
need software for watermarking too.
can this be done with photo shop ?
Need help in finding out the right plan for getting a server and domain for the same
please help me
Thx
eureca_eureca is offline
Old 15-01-2008, 05:15 PM   #2 (permalink)
slugger's Avatar
Default Re: Image editor Needed , help for starting a web page too
not sure if resizing of images according to target file size is possible or not, but u can use Irfanview to resize [dimensions] or reduce the size of the image
but if u got photshop u can do it in dat 2
photoshop can do anything with images
but a FREEWARE solution to watermarking images is waterMark V2
please help me
Thx
search the forum 4 ur answer literally TONNNZ of threads runnin which will give u all d info u will need and more
P.S.: Watermarked Wallpaper!!!! not going 2 b on my desktop 4 sure
i suggest dat u put ur logo or name on any one of the corners [a la Sanatabanta] instead of a watermrk covering the whole image
slugger is offline
Old 15-01-2008, 05:26 PM   #3 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
just make sure you have the necessary rights to watermark and redistribute the wallpapers(incase you don't produce them from scratch!)
गीक होना माँगता
victor_rambo is offline
Old 15-01-2008, 07:32 PM   #4 (permalink)
none of the pic s are copied all are shot by my friend.
some one please explain how to reduce sizes in three qualities ..that too in batch ..editing single images one by one is impossible ...
Watermarks on the image is gonna be transparent at the very right bottom corner , that too very tiny image for reference
Old 15-01-2008, 07:41 PM   #5 (permalink)
prasad_den's Avatar
irfanview >>> file >>> batch convert >>> select advanced options >>>> tweak options to your needs >>> set output directory >>> okay >>> its done...!!
prasad_den is offline
Old 15-01-2008, 07:53 PM   #6 (permalink)
Thanks
Simple image editor for amateur web designing ramborums QnA (read only) 5 04-11-2006 01:08 PM
how to block image copying from html page.. nikku12982 QnA (read only) 6 24-08-2006 04:40 PM
Google Web Page Editor BETA- What you see is what you get! ejvyas Technology News 17 11-04-2006 10:04 PM
ISO disc image Editor problem ssk_the_gr8 Software Q&A 5 15-12-2005 09:01 PM
PC not starting ..Urgent Help needed! rkb2005 QnA (read only) 4 02-09-2005 11:14 PM
