Old 03-04-2005, 06:59 AM   #1 (permalink)
Default about the folder option
in winxp i had lost the button of folder option from the control panel and titile bar give the solution to view it again
pravesh_4766 is offline
Old 03-04-2005, 07:28 AM   #2 (permalink)
Default Re: about the folder option
download a tool called tweakxp from microsoft.com
A false friend and a shadow attend only while the sun shines.
Godhatesusalllll is offline
Old 03-04-2005, 08:56 AM   #3 (permalink)
@pravesh_4766,,comfortable with registry ru???
navigate to this .....>>>>
HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\Cur rentVersion\Policies\Explorer
nd if u find "NoFolderOptions" onm the right hand pane,simply delete it
or try out this raw TWEAK!!
right click on desktop,click on create shortcut nd enter the following in the path EXACTLY...
rundll32 shell32.dll,Options_RunDLL
double click nd see if u get folder options!! ((Assuming u have winXP..wont work in 98))
if all else fails..try reinstalling IE/repairing IE frm add/remove programs...might help!
grinning_devil is offline
