Old 22-08-2004, 03:18 PM   #1 (permalink)
Default hard disk problem
When i try to format a partition which contains windows xp sp1 using
the command 'format drivename:' it gets stuck after 77% and message appears RECOVERING FROM ALLOCATION UNIT 1,319,098 and the number keeps on increasing .I RAN SCANDISK but i din't find any errors
PLEASE HELP
perk_bud is offline
Old 22-08-2004, 04:17 PM   #2 (permalink)
format using the recovery console with the winxp bootable cd.
rj2k is offline
Old 22-08-2004, 06:18 PM   #3 (permalink)
bipin_hbk
Posts: n/a
Just Format using Format command while booting with a bootable floppy if you find any bad sectors go for low level formatting. This will solve your problem
Old 22-08-2004, 11:56 PM   #4 (permalink)
busyanuj's Avatar
Default Re: hard disk problem
PLEASE HELP
first run ScanDisk in DOS mode so that the surface scan fixes all bad sector problems.
next format the drive using the command:
format <drive> /u/v
this should help.
busyanuj is offline
