Old 14-01-2008, 08:24 AM   #1 (permalink)
~[::BOoYaKa::]~
Default DVD-R Burning Question..
As you know the capacity of a DVD-R is some 4.3 GB.. Now i want to know can i add small amount of data many times on it, like i take backups, 200-300 MB at a time.. can i write to it multiple times until its capacity is reached, or i have to add full 4GB at once..?
I am confused, please help..
Thanx..
[::Eddie n Benoit Live Forever::]
REY619 is offline
Old 14-01-2008, 08:31 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: DVD-R Bruning Question..
Yes. you can use multisession. But these days writers aren't that good in burning multisession discs
desiibond is offline
Old 14-01-2008, 08:40 AM   #3 (permalink)
~[::BOoYaKa::]~
Ok thanx... Will try.. I have Asus DVD writer... Its good!
REY619 is offline
Old 14-01-2008, 11:22 AM   #4 (permalink)
TheSaint
NucleusKore's Avatar
Take care, some drives don't read multisession discs
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 14-01-2008, 11:38 AM   #5 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: DVD-R Burning Question..
Thanx..
Yes You can do Multisessions
if you are using nero take care to "on" the Option of add files (multisession) later
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 14-01-2008, 02:17 PM   #6 (permalink)
vaibhavtek
Posts: n/a
Yes
Question about EP-630 ring_wraith QnA (read only) 15 15-11-2007 04:00 PM
Help Req - LG GSA-H42N DVD Bruning Problem chi321 Hardware Q&A 4 07-08-2007 08:28 PM
i have a question Fahd.Malik QnA (read only) 4 08-02-2007 07:07 PM
a RAM question anarchy0x Hardware Q&A 8 11-01-2007 09:49 AM
ISO file bruning to CD Nimtshey QnA (read only) 4 21-09-2006 06:32 PM
