Old 13-01-2008, 05:07 PM   #1 (permalink)
evewin89's Avatar
Default how 2 disable right click???
i want 2 kno how 2 disable right click in VISTA.In winXP i used 2 disable right click from regedit bt this trick is not working in vista.
Evil Lives 4ever......
evewin89 is offline
Old 13-01-2008, 05:19 PM   #2 (permalink)
slugger's Avatar
Default Re: how 2 disable right click???
u can do dat from gpedit
just enable Remove Windows Explorer's default context menu option
User Configuration->Administrative Templates->Windows Components->Windows Explorer
and 2 disable right click of task bar and start menu a taskbar just enable d Remove access to the context menus for the taskbar option
User Configuration->Administrative Templates->Start Menu and Taskbar
P.S. d path mentioned is from Win Server 2K3, vista may have d same path
slugger is offline
Old 13-01-2008, 05:31 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
If you are using XP Home Edition and can't use "gpedit.msc" or if you want to use Registry Editor to disable context menu or if you want to write scripts fot it, then open regedit and goto:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
And in right-side pane, create new DWORD value "NoViewContextMenu" and set its value to 1.
To disable Taskbar context menu, create new DWORD value "NoTrayContextMenu" and set its value to 1.
PS: Same things will happen if you'll use gpedit.msc trick mentioned by slugger.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 13-01-2008, 05:56 PM   #4 (permalink)
vaibhavtek
Posts: n/a
^^ nice hack.
Old 14-01-2008, 12:10 AM   #5 (permalink)
evewin89's Avatar
thank u guyz 4 all ur valuable comments. actually i forgot 2 add "view" in "NoViewContextMenu" & datz y i was unable 2 do da trick....thankz 4 reminding me......***
evewin89 is offline
disable autorun on click tweety_bird_bunny QnA (read only) 3 04-11-2007 03:16 PM
Enabling right click on sites that disable it rajesh Tutorials 16 03-10-2007 04:33 PM
how can we disable right click???? dittualex QnA (read only) 2 15-11-2005 07:06 PM
how to disable right click for hyperlinked image esumitkumar QnA (read only) 13 02-12-2004 12:01 AM
