Old 02-04-2005, 11:20 PM   #1 (permalink)
Default abt partitions and 7610
i'll b glad if u could help me with these two issues:-
1)i want a free partition manager which can easily split and most importantly,merge fat32 partitions without losing data.i tried partition magic etc but those are demos ,they don't apply changes.Plz help me.
2)i have a nokia 7610 and i want to transfer data to it with my friend's win 98se sytem.nokia pc suite doesn't install on it.so is there any other way.what to do????
partition prblem is very important
PLZ HELP ME.
RJ THE GREAT
ranjodh is offline
Old 02-04-2005, 11:28 PM   #2 (permalink)
Fresh Stock Since 2005
Default Re: abt partitions and 7610
For this. Do this...........
If you have Win XP, create a partition of desired size with the help of Windows Bootable during installation.
Then after installation of windows, use the logical disk manager from Start|Run|compmgmt.msc to create other partitions....................
For Win98, i have no idea of freewares.................
khattam_ is offline
Old 03-04-2005, 09:20 AM   #3 (permalink)
but how to merge partiions.it's most important.
ranjodh
RJ THE GREAT
ranjodh is offline
Old 03-04-2005, 06:21 PM   #4 (permalink)
for ur prob on 7610:
u can transfer data via bluetooth. u"ll first have to buy a bluetooth port(around rs 300) plug it into ur friends pc and transfer the require data
paul_007 is offline
Old 03-04-2005, 06:47 PM   #5 (permalink)
but what abt merging partitions??????
RJ THE GREAT
ranjodh is offline
Old 09-04-2005, 07:08 PM   #6 (permalink)
stop smamming Ranjodh.
Here's a sloution. You will have to back your data up for this.
My Computer>Right Click>Manage>Storage>Disk Management
SatishSays.com
twitter.com/satishsays
devilhead_satish is offline
Old 10-04-2005, 12:55 PM   #7 (permalink)
enoonmai's Avatar
If you want to merge partitions without losing data, then your only bet is to use the commercial Partition Magic software. You have to get the full retail version, there's no other way. Non-destructive merging of partitions is not possible with any freeware.
Playing FEAR XP/LSW2
enoonmai is offline
Old 10-04-2005, 01:03 PM   #8 (permalink)
try this.
http://www.ranish.com/part/
It might be useful for you. Its freeware. And I have used it long back. Quite useful.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 12-04-2005, 06:24 AM   #9 (permalink)
if u remember,disk management cant merge fat32 partitions.and ranish is not a freeware.surely,there has got to be a way out
RJ THE GREAT
ranjodh is offline
