Old 02-04-2005, 08:26 PM   #1 (permalink)
jay4u's Avatar
Default Urgent help required . . . Want to flash BIOS
I had once posted my problem . . .
Hello,
Whnever i start my system, after the POST routines i get an error message stating "BIOS checksum error, Press F4 to resume". And after pressing F4 i am taken to the BIOS menu where I have to do nothing. Just press Esc key and the system starts.
Please if anyone knows what can be the solution then let me know. Should I change the CMOS battery ? This problem is really irritating me . . . Sad
The reply i got was
1. CMOS battery to be changed
2. Flash the BIOS
Now i have replaced the CMOS battery . . . but still the problem consists . . . What should i do. How to flash the BIOS. . . I have Intel original 845GBV motherboard. 2 months back i have upgraded the BIOS. If anyone knows how to flash BIOS please reply . . .
Awaiting
Passwords are like underwear... Change them often...
jay4u is offline
Old 02-04-2005, 09:45 PM   #2 (permalink)
Was the MB working properly before the previous Flashing ?
Kannan.
Binary Bits
http://www.binarybits.net
Kannan is offline
Old 02-04-2005, 09:52 PM   #3 (permalink)
dont go after flashing your bios first try out these steps
: remove and replace your cmos battery after waiting for 5 minutes
: go to bios options and use the set biosdefaults option
: go to bios option and search for "System BIOS Cacheable" option and disable it
if still the problem persists then please reply again
flashing of bios is simple but a dangerous job cause a failure can render your mb unuseable (although i have flashed mine twice)
\"I was born INTELLIGENT
But EDUCATION ruined me!!!!\"
AMD 64 3200+(Winchester), MSI RS480M2-IL, 512*2 DDR400 Hynix, Segate 80 GB SATA, LG E700SH, i-benz with Intex PS (400 W)
technoteen is offline
Old 02-04-2005, 10:18 PM   #4 (permalink)
Yeah technoteen is right.
Go for Set BIOS Defaults, if that doesn't work then think the other solutions.
Kannan.
Binary Bits
Kannan is offline
Old 03-04-2005, 10:27 AM   #5 (permalink)
jay4u's Avatar
Default Thanks . . .
I cannot find the entry System BIOS cacheable in my BIOS. But i install the latest BIOS upgrade from intel.com. It seems to work fine for now. Hope the problem is solved.
jay4u is offline
Old 03-04-2005, 02:57 PM   #6 (permalink)
Oh good.
Hope your problem is solved Jay !!
Kannan.
Binary Bits
Kannan is offline
