Originally Posted by Satissh S
His reasons were that:
1. it was very crippled and very delicate
2. he had just receivd a return stating that it hangs a lot.
3. also that the processor used were without the pins as they were in the mobo itself and also had excessive heating du to it and it has only sata drives.
i really hate when dealers do these kind of cr@p just to sell off their products...
EVERY PC component is delicate,wont 865 break when u let it fall?? nd when the dealer asks abt delicacy nd all..does he care to be cautious in handling these devices?? i bet he wud not have even heard abt anti static wrist straps or measures to take care of static...
he recvd a return stating that PC hangs a lot...nd u think intel will replace the board with this cr@p statement??? PC hangs only becoz of motherboard???? such excuses....sheeeeeeeesh :roll: :roll:
if the pins are on the motherboard then EXCESSIVE heating takes place,but when the pins are on the processor then the temp is really coooool.....rite????? damn what the hell pins have to do with temp??? imroper arrangement of heat sink nd fan will do wonders to CPU irrespective of the pins....
DONT EVER GO WITH THE DEALERS CONFIG....have a handy config in mind and on paper after researching on net,forums,mags,frnds...nd insist ONLY on predecided components...
