Old 02-04-2005, 03:08 PM   #1 (permalink)
Default Sharing multiple net connections
We in the hostel have 6 systems connected in lan in which the net connection is installed in my system.
The net connection is an airtel gprs connection.
Now my problem is that now i have two gprs connections and i was wondering is it possible for me too use both the connections so that the users on the LAN could have a faster connection.
Thing is that when i tried putting both the connections in sharing it was not possible.
All i want is to connect both the phones on the system and use my gprs hopefully for a faster browsing and download and it should work with the LAN
Thnks in advance
shriekers is offline
Old 02-04-2005, 08:39 PM   #2 (permalink)
If your ISP is same on both connections and the ISP has the negotiate connections option enabled, then you can use both the connections to increase the speed.
Kannan.
Binary Bits
http://www.binarybits.net
Kannan is offline
Old 02-04-2005, 10:39 PM   #3 (permalink)
could someone tell me the step by step procedure on what to do and what i have to inquire
is there any software required i use windows xp
Old 03-04-2005, 03:18 PM   #4 (permalink)
U don't need additional software. Your OS does the job.
About the connection settings, do a search in google.
I will post the link, when I get a good tutorial.
Kannan.
Binary Bits
Kannan is offline
