Old 08-01-2008, 02:24 PM   #1 (permalink)
left this forum longback
praka123's Avatar
Smile Help:TV Tuner card able to record DTH programs(home use only)
Pls Tell me some brands which allows the recording of progs from Sky or Dishnet etc for home use.what capability does the card needs to have to record DTH channels? Digital or Analog Card?also the prce range .Thank you.
praka123 is offline
Old 09-01-2008, 10:32 AM   #2 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Default Re: Help:TV Tuner card able to record DTH programs(home use only)
In Linux or Windows? Regardless I think any TV Tuner will do for recording DTH programs. Isn't its output the Coaxial type of cable?
FilledVoid is offline
Old 09-01-2008, 10:37 AM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
@Praka
any card would do, basically, Pinnacle and winfast cards are more pupuler and availavle in india with price tag between Rs. 2000/- to 2500/- incl all TAX...
but I dont have much information about their driver support for Linux distro... so for you my suggestion is rather the price concentration should be in finding the right model which comes with proper driver support for the Linux flavour you use
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 09-01-2008, 10:45 AM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
instead of paying 2k for a tv tuner card, try to get Dish TV's VGA settop box.
You can connect this settop box to your PC and watch TV without any extra hardware like tv tuner card.
Rs.4150 for entier package.
dishtvindia.in/static/vga.htm
there is an offer. Pay 5k and get 1yr subscription.
desiibond is offline
Old 09-01-2008, 10:49 AM   #5 (permalink)
Rubik's Uncle!!
Charan's Avatar
^^ I think it doesnt support recording..
Charan is offline
Old 09-01-2008, 02:36 PM   #6 (permalink)
pratik03's Avatar
YES it doesn't support any type of recording.
pratik03 is offline
Old 09-01-2008, 02:39 PM   #7 (permalink)
praka123's Avatar
^I hope pinnacle one is good.i am confused with the digital and analog versions with Sky or Dishnet giving digital output,I suppose a digital card will be more useful?any recommendations.budget is upto 2.5K
praka123 is offline
Old 10-01-2008, 04:58 PM   #8 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
pinnacle is damn good , using 4 2 years & DTH se bhi record hota hai .....
... W H O T ...
ax3 is offline
Old 10-01-2008, 04:59 PM   #9 (permalink)
praka123's Avatar
Ok.thx finalized for leadtek one if available here.
praka123 is offline
Old 12-01-2008, 02:20 PM   #10 (permalink)
666
solomon_paulraj's Avatar
did you do the recording... which model did you buy.. what price.. i wanna buy the same thing you did...
MSI-P35-NEO| C2D-E7300 | XV-9600GT | WD-640 | LEADTEK-DTV-1800H | CORSAIR-TWIN2X2048-6400C4DHX | ZEBRONICS-PRO M500W | SONY-DRU-V200S | LOGITECH-X90 CORDLESS
solomon_paulraj is offline
Old 12-01-2008, 05:52 PM   #11 (permalink)
praka123's Avatar
^yes for recording from sun dth for personal use.actually i asked this here for my uncle who is the principal of a famous college here.today we went to Ernakulam and brought a pinnacle pctv (?) something with Vista compatible sticker!i searched for this in pinnacle site and not found! brought for Rs 2000/- including everything.
leadtek ones were not available and the guy there told to not go for intex ones,also available is pixelview tuner card for 1.5K.
no leadtek ones were available but this pinnacle card is really goood!go for it!1 yr gurantee.
this card got stereo recording,FM recording etc.i have to wait for the news later this week.
pixelview,frontech,intex etc cheap ones are available for around 1000 rupees.
edit:OK.I Think below one is what we bought!and the price they are asking is 2800+
@solomonpaulraj:compare between leadtek and pinnacle:
pinnacle pctv 50i:
http://shopping.rediff.com/shop/prod...rompg=Pinnacle
leadtek Winfast TV 2000 XP Global
http://www.leadtek.com.tw/eng/tv_tun...&pronameid=387
praka123 is offline
Old 12-01-2008, 06:45 PM   #12 (permalink)
99.9% Idle
axxo's Avatar
i suppose any analog TV card would do it...myself using compro videomate card to record videos from tata sky..
axxo is offline
Old 12-01-2008, 06:47 PM   #13 (permalink)
praka123's Avatar
^thx aXXo.BTW,how is the quality?this pinnacle pc50i got divx support and all.also is this card able to record stereo audio from dth receiver now my uncle is gonna cursing me if it does not work
and i want to know how did u plugin the a/v plugs?or are u using the analog single ohm pin?
praka123 is offline
Old 12-01-2008, 07:02 PM   #14 (permalink)
99.9% Idle
axxo's Avatar
^ yes the Tuner card can accept three modes of Input(Normal Anolog(cable TV signal), S-Video & Composite)...
Composite cable will be provided with the digicomp that sends video signal from digicomp(receiver) to TV or PC TV Tuner card Input.
Now as far as the Audio is concerned..The O/p of receiver is stereo..but the card accepts single input through LINE IN...
So its up to us to use either mono input or a Two-One Multiplex cable to convert the stereo to mono and then send that to PC LINE IN.
The quality of Video is very good..I recommend encoding in MPEG 2(DVD) then use virtualdub or any preferred video tool & later convert to whatever format ....
axxo is offline
Old 12-01-2008, 07:11 PM   #15 (permalink)
praka123's Avatar
^OK;thank you very much!
praka123 is offline
Visa Home Basic - is it possible to use TV Tuner eagercyber Software Q&A 2 13-12-2007 09:04 AM
TV tuner card for recoeding programs! fatguysmart QnA (read only) 2 05-02-2007 09:14 PM
Tv tuner card / Graphics card for my config ... gsenthil PC Components / Configurations 4 08-09-2006 07:23 PM
Unique TV Tuner Problem (Short Circuit @ Home) quad master QnA (read only) 6 26-08-2004 02:02 PM
