Old 07-01-2008, 10:34 PM   #1 (permalink)
vaibhavtek
Posts: n/a
Question Urgent - Rename a group of files
I need to rename a group of image files. However, I want to rename them only with odd numbers, so that fileA, fileB and fileC become File1, File3, File5, File7, etc.
I know this can be easily done by Batch Programming but as i donot know that much batch programming can any member(user) can make a batch programming and give it to me for doing my said thing.
Or if there is another way u can also give that process.
Its very very urgent.
plz help me.
Old 07-01-2008, 11:55 PM   #2 (permalink)
slugger's Avatar
Default Re: Urgent - Rename a group of files
use irfanview's batch renaming feature
in the options use increment of 2 intead of 1
so depending on wat no u start with [either even or odd] u will get the same type of number in the whole batch
slugger is offline
Old 08-01-2008, 12:18 AM   #3 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
or u can use rename Master
http://www.joejoesoft.com/vcms/108
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 08-01-2008, 08:05 AM   #4 (permalink)
vaibhavtek
Posts: n/a
thanks.
Old 08-01-2008, 08:54 AM   #5 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
One of the most easy and best Renaming Tools for me is Lupas Rename. Although a DEAD project now but it still is cool, check it out at
http://rename.lupasfreeware.org/
http://www.host4cheap.org/
Sukhdeep Singh is offline
Rename The Recycle Bin Batistabomb Tutorials 9 07-11-2007 04:30 PM
group discussion (URGENT) gycapri Chit-Chat 2 24-08-2007 12:39 AM
How to rename multiple files in one time ? ANURAG SHARMA QnA (read only) 3 12-06-2007 11:09 AM
Downloading of Yahoo Group and Microsoft Discussion Group Amreshwar Internet & WWW 2 17-05-2007 06:42 PM
