Re: How do I change the default Sleep button in Start menu to Shutdown
press Windows Key...then type..power option..then Click on 'Choose when to turn of the Display'..then Advance Power option there You will Find it..somewhere..
I dont Exactly Remember its Name..
Hi guys I got it
The solution is:
Control Panel.
System and Maintenance.
Power options.
Select your power option and choose "Change Plan Settings"
Click "change advanced power settings".
Maximise "power buttons and lid"
Maximise "Start menu power button"
Click on "sleep" which will bring up options and select "Shut down"
Apply and OK.
