when i run some of my application like turbo c etc... i get the followin error
16 bit windows subsystem
c:\windows\system32\autoexec.nt. The file system is not suitable for running ms-dos and microsoft windows applications. Choose 'close' to terminate the application.
my os is Win-XP professional
what is the reason and solution for this problem? anybody......
Ok, the same problem in in digit march 2005 issue as well. Page 82.
First soln:
Try reinstalling the ms dos thing.
Goto start>run .In the open box type: "cmd".
at the comand promt, type in the follwing commands and press enter after each command: expand CD-ROM drive letter:\i386\config.nt_C:\windows\system32\config. nt
expand CD-ROM drive letter:\i386\autoexec.nt_C:\windows\system32\autoe xec.nt
expand CD-ROM drive letter:\i386\command.com_C:\windows\system32\comma nd.com
Exit
Now try reinstalling.
Second soln:
If the above doesn't work...
In notepda type in: dos=high,umb
device=%SYSTEMROOT%\system32\himen.sys
files=40
save the above with name "config.nt".
now again open a blank document and type the following entries:
@echo off 1h %SYSTEMROOT%\system32\mscdexnt.exe
1h %SYSTEMROOT%\system32\redir
1h %SYSTEMROOT%\system32\dosx
SET BLASTER=A220 I5 D1 P330 T3
save the file as "autoexec.nt".
Now locate the "config.nt" file and copy it to the %SYSTEMROOT%\system32 folder.
Do the same with autoexec.nt and command.com and restart...
Do the following and say if it works and i can try the same..
My friiend had a similar problem and he called me to solve it. I could not figure out the problem so i reinstalled Widows which of course, solved the problem...................
