Old 04-01-2008, 10:17 PM   #1 (permalink)
Elevating Humanity
The Conqueror's Avatar
Question Combining many installation in 1 ??
I want to know how to combine many product installations into 1
for eg. Autopatcher XP which automatically installed about 120-130 updates one by one without us needing to run each and every application.
can this be done with installshield ?
Regards,
The Conqueror
The Conqueror is offline
Old 04-01-2008, 10:22 PM   #2 (permalink)
slugger's Avatar
Default Re: Combining many installation in 1 ??
u can do dat usin nlite
procedure given in last months DIGIT
slugger is offline
Old 04-01-2008, 10:23 PM   #3 (permalink)
Elevating Humanity
No, i dont want to integrate the software in Windows XP cd..
I just want to create exe file which will automatically install the required software
Regards,
The Conqueror
Old 04-01-2008, 11:20 PM   #4 (permalink)
I never have to worry about manually installing updates. Windows Update automatically runs at 3 AM.
Why not just turn Windows Update on?
awesomeo is offline
Old 04-01-2008, 11:38 PM   #5 (permalink)
meowww meoww
Kenshin's Avatar
He doesn't want to combine updates...
You can find exe binders...just google for them...but i guess tat will make all exes run at same time.
"Microsoft: You've got questions. We've got a dancing paperclip."
Have fun,no worries..
Kenshin is offline
Old 05-01-2008, 08:09 AM   #6 (permalink)
Elevating Humanity
yes i dont want to combine only windows updates i want to combine software installations so that they will run 1 by one like autopatcher xp
Regards,
The Conqueror
Old 05-01-2008, 10:24 AM   #7 (permalink)
meowww meoww
Kenshin's Avatar
Will try to see if Orca can help u..
Kenshin is offline
Combining Video Clips enticer86 Software Q&A 9 30-12-2007 06:30 PM
Combining Non-Bootable & Bootable CD Iso's into a DVD arnold Software Q&A 3 26-12-2007 07:28 PM
combining two ISP.. Ricky Software Q&A 8 13-09-2006 11:33 PM
Combining Cd's to make DVD ganesh_2218 Software Q&A 8 25-12-2005 03:18 PM
Help in combining SP! and SP2 to Windows Prof XP karthik_rcs Software Q&A 15 24-03-2005 02:18 PM
