Old 01-04-2005, 01:23 PM   #1 (permalink)
kl_ravi's Avatar
Default Spybot Error - Swatkat Help !!!
Hi,
I get this error while running a spybot check ....
Error during check!: Xuron55.Installdollars (Datei C:\WINDOWS\win.ini kann nicht geöffnet werden. The process cannot access the file because it is being used by another process) ()
This is my Hijackthis log file for your analysis...
Logfile of HijackThis v1.99.1
Scan saved at 1:21:58 PM, on 4/1/2005
Platform: Windows ME (Win9x 4.90.3000)
MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
Running processes:
C:\WINDOWS\SYSTEM\KERNEL32.DLL
C:\WINDOWS\SYSTEM\MSGSRV32.EXE
C:\WINDOWS\SYSTEM\MPREXE.EXE
C:\WINDOWS\EXPLORER.EXE
C:\WINDOWS\SYSTEM\SYSTRAY.EXE
C:\PROGRAM FILES\GRISOFT\AVG FREE\AVGCC.EXE
C:\PROGRAM FILES\GRISOFT\AVG FREE\AVGEMC.EXE
C:\WINDOWS\SYSTEM\WMIEXE.EXE
C:\WINDOWS\SYSTEM\STIMON.EXE
C:\WINDOWS\SYSTEM\SPOOL32.EXE
C:\PROGRAM FILES\INTERNET EXPLORER\IEXPLORE.EXE
C:\WINDOWS\SYSTEM\RNAAPP.EXE
C:\WINDOWS\SYSTEM\TAPISRV.EXE
F:\HIJACKTHIS\HIJACKTHIS.EXE
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.kar.nic.in/
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\PROGRAM FILES\ADOBE\ACROBAT 5.0\READER\ACTIVEX\ACROIEHELPER.OCX
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar1.dll
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHELPER.DLL
O2 - BHO: (no name) - {38D4D5D0-423E-4220-B6F9-30918C2AE4A4} - C:\WINDOWS\SASETUP.DLL
O3 - Toolbar: @msdxmLC.dll,-1@1033,&Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\SYSTEM\MSDXM.OCX
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar1.dll
O4 - HKLM\..\Run: [ScanRegistry] C:\WINDOWS\scanregw.exe /autorun
O4 - HKLM\..\Run: [SystemTray] SysTray.Exe
O4 - HKLM\..\Run: [LoadPowerProfile] Rundll32.exe powrprof.dll,LoadCurrentPwrScheme
O4 - HKLM\..\Run: [AVG7_CC] C:\PROGRA~1\GRISOFT\AVGFRE~1\AVGCC.EXE /STARTUP
O4 - HKLM\..\Run: [AVG7_EMC] C:\PROGRA~1\GRISOFT\AVGFRE~1\AVGEMC.EXE
O4 - HKLM\..\RunServices: [LoadPowerProfile] Rundll32.exe powrprof.dll,LoadCurrentPwrScheme
O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
O8 - Extra context menu item: &Google Search - res://C:\PROGRAM FILES\GOOGLE\GOOGLETOOLBAR1.DLL/cmsearch.html
O8 - Extra context menu item: Cached Snapshot of Page - res://C:\PROGRAM FILES\GOOGLE\GOOGLETOOLBAR1.DLL/cmcache.html
O8 - Extra context menu item: Similar Pages - res://C:\PROGRAM FILES\GOOGLE\GOOGLETOOLBAR1.DLL/cmsimilar.html
O8 - Extra context menu item: Backward Links - res://C:\PROGRAM FILES\GOOGLE\GOOGLETOOLBAR1.DLL/cmbacklinks.html
O8 - Extra context menu item: Translate into English - res://C:\PROGRAM FILES\GOOGLE\GOOGLETOOLBAR1.DLL/cmtrans.html
O9 - Extra button: Related - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
O9 - Extra 'Tools' menuitem: Show &Related Links - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
O9 - Extra button: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRAM FILES\YAHOO!\MESSENGER\YPAGER.EXE
O9 - Extra 'Tools' menuitem: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRAM FILES\YAHOO!\MESSENGER\YPAGER.EXE
O12 - Plugin for .spop: C:\PROGRA~1\INTERN~1\Plugins\NPDocBox.dll
kl_ravi is offline
Old 01-04-2005, 02:03 PM   #2 (permalink)
swatkat's Avatar
Default Re: Spybot Error - Swatkat Help !!!
Originally Posted by kl_ravi
Hi,
Running processes:
The SpyBot SnD error is a bug in the program. The general format of the error message is like this:-
Error during check!: *various*(Datei C:\WINDOWS\win.ini kann nicht geöffnet werden.....
Where, *various* is any of the spyware/trojan name it gives.
Updating SpyBot SnD would solve the problem.
Also, Boot in SAFE mode, and run HijackThis, and select red entry in the above log, and click "fix".
After this delete this file, if you can find it:-
1] SASETUP.DLL
After this, run McAfee Stinger and perform a full system scan.
http://vil.nai.com/vil/stinger/
And, using AdAware, perform a full system scan.
http://www.lavasoftusa.com/software/adaware/
Then run CCleaner and CleanUp! and reboot to normal mode.
http://www.ccleaner.com/
http://cleanup.stevengould.org/
And, just to make sure that there is nothing wrong in Win.ini, open the file in NotePad, and see the entry infront of the line run=.
http://swatrant.blogspot.com/
swatkat is offline
Old 02-04-2005, 10:29 AM   #3 (permalink)
I prefer using AdAware, perform a full system scan.
Or
Microsoft AntiSpyware beta
http://www.microsoft.com/athome/secu...e/default.mspx
divyaansha is offline
Old 05-04-2005, 08:07 AM   #4 (permalink)
kl_ravi's Avatar
Hi Swatkat,
This the hijackthis log after performing the system cleanup...Is it ok ?
Scan saved at 8:04:46 AM, on 4/5/2005
Running processes:
C:\PROGRAM FILES\NORTON INTERNET SECURITY FAMILY EDITION\NISSERV.EXE
C:\PROGRAM FILES\NORTON INTERNET SECURITY FAMILY EDITION\IAMAPP.EXE
C:\PROGRAM FILES\NORTON INTERNET SECURITY FAMILY EDITION\NISUM.EXE
C:\WINDOWS\SYSTEM\DDHELP.EXE
O2 - BHO: (no name) - {38D4D5D0-423E-4220-B6F9-30918C2AE4A4} - (no file)
kl_ravi is offline
Old 05-04-2005, 11:36 AM   #5 (permalink)
swatkat's Avatar
The file has been deleted, but the CLSID remains, you can remove it using HijackThis or BHODemon.
http://www.definitivesolutions.com/bhodemon.htm
swatkat is offline
Old 05-04-2005, 01:53 PM   #6 (permalink)
Another Brick in the Wall
drgrudge's Avatar
This is a Tibs adult content dialer related sypware thing with the name sasetup.dll.
When you fix these types of entries with HijackThis, HijackThis will attempt to the delete the offending file listed. There are times that the file may be in use even if Internet Explorer is shut down. If the file still exists after you fix it with HijackThis, it is recommended that you reboot into safe mode and delete the offending file.
drgrudge is offline
Old 08-04-2005, 01:16 AM   #7 (permalink)
swatkat's Avatar
Sometimes the CLSIDs are not deleted, you have to delete them manually using Regedit. Do this.
Go to Start? Run and type regedit and press ENTER.
Then, here navigate to HKEY_Local_Machine> Software> Microsoft> Windows> Current Version> explorer> BrosersHelperObjects.
Here right-click on the BHO CLSID and clikc "Delete".
swatkat is offline
