Old 01-04-2005, 12:02 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default New OS on old hdd ! ! !
have a 80 gb hdd ... 4 partitions of 20 gb each ...
Os installed : win 98 on 1st partition & win 2000 on 3rd partition ...
data is on rest of the partition ...
now wanna remove 98 & make only w2k as my OS ...
how should i go about ???
step by step guide ... plz ...
ax3 is offline
Old 01-04-2005, 06:00 PM   #2 (permalink)
pirates1323's Avatar
Default Re: New OS on old hdd ! ! !
Ok follow the steps........
1.Boot into windows 2000 and go to system properties Advanced Startup and recovery and choose windows 2000 as a default operating system and uncheck display list of operating system for 30 seconds........now u can't boot into win 98
2.Now if u have windows 98 boot disk or floppy....boot throght it.......and choose start computer with cd rom support option and on the command line type ur floppy drive letter or cd rom letter...... Example "a:" and then press enter if u have floppy and if ur CD letter is "g" type "h:" and hit Enter...............Then type "format c:" and label it as DUMP or whtever.....
OR I think u can also format with in the windows just right click which drive to format and then click format .
Restart now you have single OS and ur c: drive is formatted........
pirates1323 is offline
Old 01-04-2005, 06:54 PM   #3 (permalink)
 Macboy
goobimama's Avatar
I think you will be able to format the C drive from windows explorer itself, just right click c: and format.
I'm like a bird... :)
goobimama is offline
Old 01-04-2005, 07:34 PM   #4 (permalink)
lol u idiot firstly windows 98 is installed and as default windows 98 is boot up...........if the user not choose the list of operating systems displayed.........he will boot to windows 98.......so if he formatted his c: within the expplorer his computer will not work mate.............Also i think he also can't format within the explorer.......me think it willproduce an error......
Old 01-04-2005, 08:40 PM   #5 (permalink)
 Macboy
goobimama's Avatar
listen...you....idiot. AFTER the dude sets his boot.ini to boot to windows 2000, and AFTER booting into windows 2000, it is very much possible to format the C:. been there, done that.
Old 02-04-2005, 12:43 AM   #6 (permalink)
swatkat's Avatar
i think this is not simple!
Because Windows 200 places files reponsible for Windows 2000 in C:\ Drive. These files are :-
1] ntldr
2] ntdetect.com
3] boot.ini
and some other depending on Hardware config.
And, if you edit boot.ini and then format C:\, then these files will be deleted and you cant boot to Win2000 too. Because Microsoft MBR always boots to "Active Partition" and it must be Primary too.
So, MBR always boots to C:\ Drive and executes "Ntldr" and it reads the boot.ini and presents the options list.
If you foramt C:\ drive, "ntldr" will be gone, and you can't boot at all.
One solution is to keep the above mentioned System files in C: drive and delete all othe contents of C: drive.
or another one is to keep the above mentioned files in C:\ drive as it is, and then using softwares such as Partition Magic, move the content of E:\ (Win2000 drive) to C:\ drive, with all the references being updated by the Partition Magic. And then edit boot.ini to alter the path for system folder of Win2000.
but, these two are untested!!!!
or, format both C:\ drive and E:\ drive (after backing up data), and then install Win2000 in C:\ drive
http://swatrant.blogspot.com/
swatkat is offline
Old 02-04-2005, 07:01 AM   #7 (permalink)
Satissh S's Avatar
Hey Here is a simple solution! Iam a novice but my guts say that i shd post this.
1. Insert the win98 cd in yr cd drive.
2. when booting frm your cd select (2) start comp, with cd rom supprt.
3. run fdisk from the cd
4. select (3) set active patition as and the select the drive.
hmmm...... I have two 40 gb hdds may be it wrkd then. If Iam wrong plz dnt b harsh on me!!!
Call it Emacs,
Love it or Leave it.
Satissh S is offline
Old 02-04-2005, 09:59 AM   #8 (permalink)
hmm......
Old 02-04-2005, 01:16 PM   #9 (permalink)
swatkat's Avatar
what!!!! it was a TYPO. it should be read as " if you edit boot.ini and then format C:\, then these files will be deleted and you cant boot to Win2000 too"
Edited in my above post.
swatkat is offline
Old 06-04-2005, 11:36 AM   #10 (permalink)
ax3
ax3's Avatar
4 fresh installation of OS ! ! !
i have -- c: win98 & e: w2k ...
removing above both OSes &
installing win XP pro ...
how should i do it ???
step wise .... plz ...
... W H O T ...
ax3 is offline
Old 08-04-2005, 11:33 AM   #11 (permalink)
ax3
ax3's Avatar
hey ... techno guys help me ...
me , bored with w2k ...
XP install karna hai ...
... W H O T ...
ax3 is offline
Old 08-04-2005, 12:08 PM   #12 (permalink)
Format both the partition with partition magic dos boot disks.............
