Re: How to send FAX via PC..?
Go to control Panel
Open Add or Remove Programs in Control Panel.
Click Add/Remove Windows Components.
In the Windows Components Wizard, select the Fax Services check box, and then follow the instructions on your screen.
To open Fax after installation, click Start, point to All Programs, point to Accessories, point to Communications, and then click Fax Console.
Source : windows help
