View Poll Results: Do you use tweaking proggies??
What are those?? 1 8.33%
Of course I do!! What the hell do you think. 10 83.33%
No I don't need them. My computer works fine without them. 1 8.33%
Voters: 12. You may not vote on this poll
Old 01-04-2005, 05:39 AM   #1 (permalink)
Fresh Stock Since 2005
Default What Programs Do You Use To Keep (or Make) Your Computer Smo
What Programs Do You Use To Keep (or Make) Your Computer Smooth-running And Fast??
Here's what i use....... [I have a P4 1.7 GHz with 128 Mb RAM on a 40 Gb HD and am running XP Home and Pro (Dual Boot)]
For Registry Cleaning and Optimization
>>Registry Mechanic 4.0
>>RegSupreme Pro
>>Advanced Registry Optimizer
>>Tune-Up Utilities Registry Clean Function
For Quick PC Booting
>>Inkline PC Booster (Used once and uninstalled. This does the job)
For smooth running
>>CacheBoost Pro
>>PcBoost
>>Tune-Up Utilities
For Better Disk Access
>>O&O Defrag Pro
>>Defagmentor Premium
For stopping unnecessary Spywares which slow the computer down
Ad-Aware SE
For Cleaning the junk
Dustbuster XP
Windows XP's in-built Disk Cleaner
Do you have any other suggestions?? Please post..........
khattam_ is offline
Old 01-04-2005, 09:09 AM   #2 (permalink)
vysakh's Avatar
Here's what i use....... [I have a P4 2.0 GHz with 384 Mb RAM on a 40 Gb HD and am running XP Pro + SP1]
Ad-Aware SE
Spybot SnD
Hijackthis
CCleaner
Spyware DOctor
Anti-virus
Avast!
Incompatible message format
vysakh is offline
Old 01-04-2005, 09:50 AM   #3 (permalink)
pirates1323's Avatar
Naa me using the all in one System Mechanic 5 Professional
pirates1323 is offline
Old 01-04-2005, 11:51 AM   #4 (permalink)
geek_rohit's Avatar
Norton Speed Disk for Defrag.
Spybot Search & Destroy for anti-spyware.
Norton SystemWorks for overall system tuneup.
TweakUI for general tuning.
SportZForumZ - We Know Your Game Better
http://www.sportzforumz.com
My Site & Blog
http://www.rohit-sharma.com
geek_rohit is offline
Old 01-04-2005, 05:27 PM   #5 (permalink)
Laptoping
Sourabh's Avatar
instead i would say make this the topic, 'What Programs u Don't Use To Keep (or Make) Your Computer Smooth'
i dun have any av/firewall/spware/adware/malware anything
pure windows XP, builtin firewall for my 24 hrs dialup connection and have no worries the day it becomes a lil too much messy i reinstall it
usuall a reinstall every 2 weeks
the best way to keep a system running smooth
but u need to be a lil careful where u save and backup ur files and folders before formatting and reinstalling the OS again
i always believe that if u are a lil careful, there no need for a AV atleast for personal home use
but yea then again ppl wod say y use condoms when u can control urself and be careful..!!
Sourabh is offline
Old 01-04-2005, 06:13 PM   #6 (permalink)
hpotter606's Avatar
It would be better if you use an AV.
Why reinstall every 2 weeks? you should atleast use it for a month!!
But its your choice ofcousre
I too dont use any tweaking tools. My PC runs finer without them. I have used System Mechanic but not satisfied with it. But i rather use NAV 2004
hpotter606 is offline
Old 01-04-2005, 09:15 PM   #7 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
The only thing I use is HijackThis and Avast as an antivirus.
FilledVoid is offline
Old 01-04-2005, 09:25 PM   #8 (permalink)
Laptoping
Sourabh's Avatar
well 2 weeks was an exaggeration
its like once in a month
but yeah there have been times when i had to do this like 3 times in 3 days when i messed my gfx drivers
Sourabh is offline
Old 01-04-2005, 10:32 PM   #9 (permalink)
Satissh S's Avatar
I use spybot S&D and Zonealarm firewall!
My specs are p4 3 ghz , 1gb ram ,intel 865 mbo; It's running smooth!
By the way, u guys ever tried zonealarm, it rocks!
Call it Emacs,
Love it or Leave it.
Satissh S is offline
Old 03-04-2005, 12:43 AM   #10 (permalink)
i use avast 4.6 ,Microsoft Antisyware, speed fan, ands thats all
Happy Computing :lol:
krishnathelord is offline
Old 03-04-2005, 01:46 AM   #11 (permalink)
thats the best example i ever came across to make things clear and simple!!!! .. hey buddy u a teacher by ny chance!!!!
iam really amazed now-a-days ..my PC has crossed a month's time frame without reinstallation...i guess NAV,adaware,spybot,system mech.,etc. are doing the job pretty gud...!
grinning_devil is offline
Old 03-04-2005, 07:52 AM   #12 (permalink)
I use slackware linux and I try to compile most applications from source ... that makes it smoother ...
On windows, I use cacheman, RAMDef, and CCleaner, thats all I need.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 03-04-2005, 09:36 AM   #13 (permalink)
Distinguished Member
anandk's Avatar
Ace Utilities for Cleaning junk files, removing invalid shortcuts, cleaning registry. (Try Tune-Up Utilities, CCLeaner, AntiTracks)
Registry Compacator (or Compressor) for compacting the registry.
BitDefender for AntiVirus. (Try AVG, Avast)
MS AntiSpy for removing spyware. (Also AdAware, SpybotSD)
Defrag Disk once a month.
If you can lay your hands on Fix-It Utililites, try that too.
Use them and then select those which suit you the best !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 03-04-2005, 09:49 AM   #14 (permalink)
anandk's Avatar
additionally use tune-up utilities to disable 'xp eye candy' like cursor shadows, etc, fo Maximum Performance.
some services are not required if you dont use internet or if yours is a stand-alone pc. these can be disabled or made manual too ! but take a litle care in this case ! also keep a check on your start-ups. WinPatrol can help you here.
Microsoft® MVP
anandk is offline
Old 03-04-2005, 10:38 PM   #15 (permalink)
hey i m using Mandrake nowdays it's cool man ,
find all the thinks integrated in base...
but couldn't install my internal modem properly,
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 04-04-2005, 12:12 AM   #16 (permalink)
Ashis's Avatar
Running Windows XP Pro & Fedora Core 1 with a
config of 2.4 GHz P4 512 MB RAM & 80 GB HDD !!!
I use no Special Software (.....Xpect)
TweakUI & Microsoft AntiSpyware
I use NIS 2005
Ashis is offline
