Old 03-01-2008, 02:51 PM   #1 (permalink)
Deadman Walking
Batistabomb's Avatar
Default userinit.exe deleted please help
Guys i mistakenly deleted userinit.exe , a user login entry from regedit, now my system whenever clicking the username and password, coming back again to display screen saying ,system is log-off login again,so to re-enter this entry in regedit i tried to go to safe mode and recovery console,but not able to log-in again it was log-off, so is there any way so that i should open regedit
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 03-01-2008, 02:55 PM   #2 (permalink)
vaibhavtek
Posts: n/a
Default Re: userinit.exe deleted please help
did u have 2 pc or one.
if 2 i have trick.
just reply.
Old 03-01-2008, 02:56 PM   #3 (permalink)
Deadman Walking
mine is a LAN with many systems, so no problwm what trick you had ?
Learn to live... &
Live to learn...
Old 03-01-2008, 03:17 PM   #4 (permalink)
vaibhavtek
Posts: n/a
if u know the location of usernit.exe in windows folder then,
copy the ussernit.exe file from other pc to pen drive.
and then go to repair option using OS CD.
then copy the usernit.exe from ur pen drive to the location of ur pc (using repair option) and then restart it must work.
i must help.
just try
not joking it worked for me many time.
Old 03-01-2008, 03:33 PM   #5 (permalink)
Deadman Walking
vaibhav mine is office computer, if i had CD of XP, no need to post here, no CD, and no CD drive ,only usb acess
Learn to live... &
Live to learn...
Old 03-01-2008, 04:00 PM   #6 (permalink)
vaibhavtek
Posts: n/a
can't do anything wait for other members
Old 03-01-2008, 04:03 PM   #7 (permalink)
Deadman Walking
dude all of the red coloured avatars changed to blue, do you observed your's and mine ,red parts in the avatar are coloured blue
Learn to live... &
Live to learn...
Old 03-01-2008, 04:16 PM   #8 (permalink)
Think Zen.
ray|raven's Avatar
Looks like your monitor's gone,i see ur avatars as red.
As for ur problem,if u have a FDD get a bootable floppy disk with that file in it.
Regards,
ray
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 03-01-2008, 04:22 PM   #9 (permalink)
Deadman Walking
i said already that i have only USB devices acess, so having a CD or bootable floppy is not a matter for any guy to solve a problem i think, i tried also remote desktop connection but of no use
Also for my login , all of the red parts of the avatar are looking navey blue, my monitor is ok, this happened only after after noon 2pm
Learn to live... &
Live to learn...
Old 03-01-2008, 05:02 PM   #10 (permalink)
evewin89's Avatar
few months back, i also did something lik dis & i was unable 2 login so i booted in my other os (win2k3) & i jst copied userinit.exe in XP drive & my prob. was solved. i was lucky that i had dual boot that time..
Evil Lives 4ever......
evewin89 is offline
Old 03-01-2008, 05:06 PM   #11 (permalink)
Deadman Walking
yes, solution for this is possible only if we have a XP cd or a floppy disk, so we cannot solve this without any media
Learn to live... &
Live to learn...
Old 03-01-2008, 05:09 PM   #12 (permalink)
Think Zen.
ray|raven's Avatar
You could try using linux from a usb.
You did say u had usb access right,
Download SLAX/Puppy/DSL and install it on the usb and copy the file from there.
Here's a tutorial covering installation of SLAX on USB.
http://pendrivelinux.com/2006/09/20/...ne-usb-slaxzip
Regards,
ray
Old 03-01-2008, 05:11 PM   #13 (permalink)
evewin89's Avatar
so watz ur plan 2 solve da prob.??
evewin89 is offline
Old 03-01-2008, 05:15 PM   #14 (permalink)
Deadman Walking
iam trying to make a usb pen drive to boot instead of floppy bootable disk, i am not sure this is possible
Learn to live... &
Live to learn...
Old 03-01-2008, 05:33 PM   #15 (permalink)
vaibhavtek
Posts: n/a
ur monitor is gone.
Old 03-01-2008, 05:38 PM   #16 (permalink)
Deadman Walking
Originally Posted by vaibhavtek View Post
ur monitor is gone.
now everything is ok dear
Learn to live... &
Live to learn...
Old 03-01-2008, 06:07 PM   #17 (permalink)
vaibhavtek
Posts: n/a
good
To see Deleted History vaibhavtek Tutorials 26 26-09-2008 03:55 PM
Partitions Deleted!!! HELP!!! HELP!!! Aseem Nasnodkar QnA (read only) 2 24-10-2005 08:27 PM
ICO Deleted !!! rajkumar_personal QnA (read only) 2 27-07-2005 03:05 PM
deleted Rexon QnA (read only) 10 03-09-2004 02:05 PM
