Old 31-03-2005, 10:34 PM   #1 (permalink)
Default XFX 5200 problem
i installed a XFX5200 card in my intel 865 GBF and it keeps giving some error message saying thet the new hardware is not installed properly etc... it then starts dumping physical memory on the hard drive.
please help me
letsbefrends_2001 is offline
Old 31-03-2005, 10:38 PM   #2 (permalink)
welcome to the forum mate. First check if the card is inserted properly making sure it slots in perfectly. Second try using someone elses card into the AGP slot and see if it still gives errors. 3rd try slotting in your card into some other system and see if it works. The last two will tell you if the card is the issue or not. If it is so then take it back to the dealer and get another one assuming it is still within the warranty period.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 31-03-2005, 10:39 PM   #3 (permalink)
why need title?
bharathbala2003's Avatar
this belongs to the H/W section..
well as far as ur prob.. if the new hardware is not installed properly plz reinstall it with the drivers u got along with it.. if not search up on nvidia site and get the latest driver for your os
http://www.nvidia.com
bharathbala2003 is offline
Old 01-04-2005, 12:25 AM   #4 (permalink)
Well if you see the display onscreen, it means your AGP is seated properly. If it dumps physical mem to the HDD...could be that you need new drivers / IRQ conflict ? Reset your BIOS to factory settings, clean boot. And post the result.
DON\'T waste money on expensive ipods. Simply think of your favourite tune and hum it. If you want to \"switch tracks\", simply think of another song you like and hum that instead.
gamefreak14 is offline
Old 01-04-2005, 07:47 AM   #5 (permalink)
Laptoping
Sourabh's Avatar
Well seems a driver issue, Start ur PC in safe mode and install the latest nvidia drivers
and restart ur PC to check if everythings allrite now
Is this the first time that u r getting the dumping the physical memory to hdd?? mebbe it cod be due to some other reason
first check with the drivers
Sourabh is offline
Old 08-04-2005, 06:02 PM   #6 (permalink)
Default reply
well i did that. i even formatted my computer and reloaded winXp, but the problem keeps recurring. it seems that when the card gets heated up it messes up for if i shut down the PC for some time and then reboot, it works fine for sometime and then starts all over again.
Old 08-04-2005, 09:40 PM   #7 (permalink)
NikhilVerma's Avatar
Did you buy a second hand card?? And did you try placing your own card into somebody else's computer??
NikhilVerma is offline
Old 08-04-2005, 10:34 PM   #8 (permalink)
Laptoping
Sourabh's Avatar
well make sure u have atleast a 350 W PSU of local make to run ur fx5200 also make sure that ur system is properly ventilated
if u have space for 80mm fans, make sure u buy urself the fan
bundle all the cables that create a mess and block air passage with a rubber band
its most probably an overheating problem, damn the fx5200 doesnt have a cooler fan
Sourabh is offline
Old 09-04-2005, 08:32 PM   #9 (permalink)
1. Open the motherboard cover when your pc is running and ensure that the onboard AGP fan is running fine with no hitches.
2. Have you installed your mobo drivers? Please post the exact words you see @ BSOD.
2. Install win 98 and run a 3dmarks/Doom 3. See if your pc is running well.
This will help you to troubleshoot where the problem actually lies.
@Sourabh -My card has a fan
