I thought that this thread might help newbies in Photoshop, c++,Java, Flash etc. who need to refer to books or ebooks for perfecting the above...if ebooks are illegal plz dont post the links...
For a start:
Java - The Complete Reference by Herbert Schildt
p.s. i myself need sumthing 4 flash
~YOU LEARN FROM UR FAILURES , OTHERS LEARN FROM YOUR SUCCESS...
@Blitzkrieg: If you're a Flash starter, look at the 'Teach yourself Flash in 24 hours' series from SAMS/Techmedia. Its good and it will give you a good headstart in learning Flash. You can always migrate to the Flash Bible and the ActionScript Bibles from Wiley once you're comfortable with Flash design.
Playing FEAR XP/LSW2
