31-03-2005, 12:45 AM
We Both Have a Mouse!!!
Why is my pc slow???
it is now about 6 months that i have bought my new pc.
config:
1.pros:amd 64bit 3000+
2.mobo:msi k8mm-ilsr (bought this b'coz wanted onboard graphics due to money factor).
3.ram:matrix 512mb 400 fsb (bought this b'coz 2x256 hynix 400fsb did not worked on my mobo??).
hdd:samsung 80gb sata.
and
no additional graphic card is installed.
now my question are
1. why does it takes 5 to 6 scrools of bar at the time of boot in xp w/o sp and if sp2 is installed it increases to 7 to 8 scrools,
on the other hand sempron 2200+ with krypton mobo and 128mb ram does xp sp2 in less than 3 scrools.
2. what is inferear in my config.
pls reply
31-03-2005, 03:31 AM
tell me, when did u last installed windows xp
thats all the bottel necks i can think of
31-03-2005, 06:39 AM
Laptoping
well its usually coz of free space on the hdd
also if u have a 9x OS on c: and xp on other drives the load up time increases
also the hdd which u previously had was smaller in capacity than ur new one
but the bootup time shldnt be a issue as far as u zip thru Xp tasks without having to wait a sec like on lower configs after all thats wht matters
31-03-2005, 12:26 PM
Windows XP loads Services during those "scrolls".
Have you defragmented your HardDisk? Which AntiVirus do you use?
http://swatrant.blogspot.com/
31-03-2005, 12:41 PM
thanks for your replys guyes,
to sunnydiv: i installed it 2 days back(xp w/o sp b'coz i was fedup with the slowness of sp2).
to Sourabh: i only have 1 hdd (samsung 80 gb sata), it is single boot, xp is installed on c: drive(10gb,ntfs) and i allways format the drive before installing a new os).
and yes after the windows is open every thing is swift.
to swatkat: yes, i have defrag my c: after fresh installation and i have norton system works 2004.
but what u guyes think i should replace or upgrade in my config??
and
still the boot time of sempron is fast WHY??
C2D E6750@3.6GHz - XFX 650i Ultra - XFX 8600GT - 2x1 2GB 800MHz JetRam - CoolerMaster eXtreme Power Duo 600W - 750GB HDD - LiteOn LightScribe DVD RW -
HP W1907 19" Wide...
and Altec Lansing ATP3...
31-03-2005, 11:20 PM
Who stole my Alpaca!
Hi,
Out of curioisty , did you experience the slowness right after the reinstall of Windows Xp? Just for names sake check the event viewer which can be found in Start>Control Panel > Administrative Tools> Event Viewer and check if you can find any weird errors in there. Also you could check for latest Drivers for your various devices. Hope this helps.
Also check this link out
http://www.blackviper.com/WinXP/supertweaks.htm
01-04-2005, 12:14 AM
use an anti spyware and remove all the spywares tht might be present 8)
01-04-2005, 12:24 AM
Norton adds up a LOT of Services to Windows xp, and these will load during those "scrolls".
If you backup of SetUp files/CD of Norton, then uninstall Norton, and check the bootup time.
01-04-2005, 07:52 AM
Systemworks is a real bummer when it comes to load up times. It usually loads the system monitor, the AV, Norton undeleter and many others. So dont be surprised if your loadup time is high. With Norton their motto is "slow baby slow" !!
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
01-04-2005, 12:03 PM
thanks for your replys guys.
after oc my pc by 10%(from2.0 to2.2) the scrolls are reduced to 3.
and after oc my pc does not sart at the first time i push the power button, the fan works but screen is not turned on and start my pc i have to push the restart button.
but every thing else is fine.
02-04-2005, 09:27 PM
delete all junk from hdd so that u can increase theamount of free space(maybe u r running low on the amount of hdd space) or how about increasing the ram...how much ram do u have installed?....how about compacting the windows registry?or maybe it just a case of the hdd is highly fragmented...just run the defrag(considering that all else is ok in your system
02-04-2005, 09:34 PM
Amd Rulz
How do u guys calculate the ghz of an amd.i meam 64 bit 3000+ calculates to how many ghz[/b]
A false friend and a shadow attend only while the sun shines.
04-04-2005, 10:08 PM
well...3000 translates into 3 ghz right???
04-04-2005, 10:45 PM
Nope AMD uses a different model numbering convention apart from intel which uses a straight GHz convention.
A AMD 64 bit 3000 translates although the clock speed is lower than the intel counterpart it runs as fast as a Intel Pentium 3.0 GHz.
You can find numbering conversions & other related specs at the amd site.
www.Oobertech.net
06-04-2005, 04:32 PM
Tux Fan
hi guys,
anyone know how to remove msn msg frm start up
it tried but it just comes back every damn time i log in to messenger
06-04-2005, 04:50 PM
When you use messenger for one time after using it, it again fixes itself up in the startup. Use something like System Mechanic's startup guard
SatishSays.com
twitter.com/satishsays
09-04-2005, 01:45 PM
Originally Posted by shaunak
hi guys,
Start MSN Messenger
Go to Tools>Options
Click on the General tab
Uncheck the option 'Automatically run Messenger when I log on to Windows'
Click Apply
10-04-2005, 08:10 PM
really confusing...there should be one standard  cpu speed convention...so that for regular people like us don't get confused or misled...something similiar should be done to the hardware and software industry in India as it was done with the mobile phone industry...setup up a regulatory industry which setups up certain guidelines regarding the phone numberibg tariffs...etc....what u think guys?????
13-04-2005, 10:51 AM
#19 (permalink)
well, no insult meant to digen, but he made a SLIGHT mistake bout the naming convention.
the 3000+ in athlon64 3000+ has nothing to do with the P4 3 ghz.
3000+ means the athlon64 gives as much computing power as a standard athlon running at 3 ghz.
or put another way, a standard athlon will have to run @ 3 ghz to give the same performance as the athlon64 3000+
check out this link if you want to know more: http://www.bit-tech.net/review/85/
13-04-2005, 02:16 PM
#20 (permalink)
boss u got a bad mobo or power supply go get them checked & replace them.
when pc does not start on the first try take it to the doc.
13-04-2005, 05:54 PM
#22 (permalink)
REMOVE NORTION AND SEE UR LOADING SPEEDS INCREASES BY 40%..
TO REMOVE MSN, GO TO RUN-MSCONFIG-STARTUP-UNCHECK THE UNWANTED..BE CAREFUL:::NOT TO UNLOAD THE WANTED FROM THE STARTUP THOUGH!!..
Rajeev V Nair
13-04-2005, 09:07 PM
#23 (permalink)
well norton is a very resource hungry application...removing it will give a decent boost to your system...but also try cleaning out your registry(only if u know what to do...make a backup before doing anything to it) and then compacting it, defraging your system(use either ms defrag or any other thiord party defrag utility...u can usually find one in one of the older digit cd/dvd'salso try freeing up some space on your hdd ok????try it out out
13-04-2005, 11:51 PM
#24 (permalink)
i will defenately look up to what u guyes told me.
cheers
15-04-2005, 05:20 PM
#25 (permalink)
Dear Vishakdatta ,
If u dont know something,please be quiet..Ur's was a foolish answer. the figures in amd's athlon/duron/smpron/athlonxp/athlon64 series means something different. example: 1600 + means it is not running at 1600mhz,but at 1399 or 1424 mhz. but the performance by all these cpu's can be compared by the same class cpu of the competitor. Ex: athlon xp 2400+ running at 1.9ghz will be equal or better in performance that of a p4 2.4 ghz. and Sempron 2400+ runs at 1.8 or 1.6 ghz can perform equal or better than a celeron 2 ghz or faster. if u need authorized discription, please visit www.amd.com.
AMD people always think megahertz is not the only critieria which measures a PC performance..
Mods : please look into the authenticity of the postings...
otherways this will be a bluffing spot soon.
Rajeev V Nair
26-05-2005, 04:26 PM
#26 (permalink)
Linux is the best (!)
I have been running my system on Red Hat Linux for the past two years. My friend who has a windows installed could'n belive that my comp was running like a young horse.
There are other portability issues with linux but speed wise it is good.
Search this Thread |
