LinkBack (1) Thread Tools Search this Thread Display Modes
Old 30-03-2005, 10:12 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default water cooling
Hi everybody.Can somebody tell me about Water cooling the CPU what the system costs and is it available in India.
IN HOUSE GEEK!!!!!!!!!!!!!!!!!!!!
chirayu garg is offline
Old 31-03-2005, 01:57 AM   #2 (permalink)
sms_solver's Avatar
has water cooling arrived. I don't think it has arrived
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 31-03-2005, 02:44 AM   #3 (permalink)
What is Water cooling.
Can you explain?
prateekgoel123 is offline
Old 31-03-2005, 03:35 AM   #4 (permalink)
sunnydiv
Posts: n/a
well pra, it is simple using water to coll down various component of your system instead of air
with help of a water pump, and some pipes
one of the mod here (dexter) tried it, and ended up frying his MOBO so, try going for a very prefessional kit .
Old 31-03-2005, 09:04 AM   #5 (permalink)
Walter cooling is one of available coolng solutions mainly for lowering the temp of your cpu which will prolong the life of your cpu. The conventional cooling soultions invovles using Air based coolers with copper heat sinks. Water cooling is relatively new and quite expensive as well. And as of now they are extremely difficult to procure in India. Mumbai might be your best bet.
For more product info go here:
http://www.xoxide.com/watcoolkit.html
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 31-03-2005, 09:30 AM   #6 (permalink)
well in same forum i did search on this for curiosity sake..........the knowledge which i got is this....it costs ard 8k+ also u need to tc about lot of thing or else if any leakage occurs u r gone.........i think in india its still a new thing...
magnet is offline
Old 31-03-2005, 02:36 PM   #7 (permalink)
aadipa's Avatar
To my knowledge Dexy didn't fried his mobo, though he got a leak.
1 aadi + 1 aadi = 1 full
aadipa is offline
Old 31-03-2005, 09:18 PM   #8 (permalink)
Well chirayu, there is this clan called "overclockers." These overenthusiastic dudes are gifted with loads of adrenalin and love to spend their free time increasing the speeds of their processors, the RAM, and in turn their overall rig (read computer).
For the processor, they will increase the clock multiplier and the FSB, or both. Then in order to sustain those high speeds, they have to provide more voltages. This will result in heat - more heat than usual.
So they will try to cool their computers. First they will uses exotic copper heatsinks that appear to occupy all of their cabinets! Then they will install huge fans that produce small storms and a hell lot of noise
All this while, they will keep upping the speed of the processor and keep cooling it. Now either they have deep pockets (heck all of them do), or are unable to tolerate the sound produced by the 7 fans they just installed to keep the computer cool.
Now they turn to water cooling -- a system by which water is used to achieve cooling. There is a water block that sits on top of the processor, water runs via tubes through this water block. The heat from the processor is transferred to the waterblock and from the water block the water that is circulating inside the water block. The heat is then removed from the warmed water via a radiator. The water moves around the whole system of radiator, tubes, and waterblock by means of a water pump. Of course, all the water flows inside pipes. Leaks can be disasterous. Some coolants are also added to the water to further enhance the cooling.
Yes, it is avaible in India. In fact a few months back, Chip carried an article on it. Sorry, don't know the contact where you can buy it though.
DH.
Where is the wisdom we have lost in knowledge?
Where is the knowledge we have lost in information? - (Choruses from the rock - T.S. Eliot)
Doc Holliday is offline
Old 01-04-2005, 12:16 AM   #9 (permalink)
Its more like converting your PC into a car both use the same cooling tecnique
**** happens
pradeep_chauhan is offline
Old 01-04-2005, 12:48 AM   #10 (permalink)
sunnydiv
Posts: n/a
which friend his mobo, which was around the time when digit did a article on him, so he had to get mobo of a friend to show them how it works
:LOL:
Old 02-04-2005, 09:40 PM   #11 (permalink)
WHAT? water cooling....what is this....is this similiar to the raditor system used in car...do i have to install a radiator near my computer..what if there is a water leakage?will the system short-circuit? or should u just install a 2 ton a/c with the cold air blowing directly onto the cpu itself
where ever i may roam where i lay my head is home
musafir is offline
Old 05-04-2005, 02:12 PM   #12 (permalink)
Water hohohoh its nono when it comes to a Computer. There is no such water cooling available for a pc. dont forget it that though ur pc might be as fast as ur car it isnt A CAR to hav water cooling.
ashvidia is offline
Old 05-04-2005, 02:20 PM   #13 (permalink)
Yeah Dexter tried it once.
Lovedeep Wadhwa
cheetah is offline
Old 05-04-2005, 03:05 PM   #14 (permalink)
ashvidia, dude if you got no idea as to what water cooling is then please do some research or atleast look at the links which have been posted. Pradeep_chauhan is right it is pretty much like a cooling technique in a car.
AMD 64 3500+ Venice
icecoolz is offline
Old 08-04-2005, 03:02 AM   #15 (permalink)
Prime ABGB, Lam Rd. Mumbai.Ask for Gulbir Bhatia.Ph.23855500 . I had got a TT Aquarius II liquid cooling sustem some timeback for around 7K from them. Cool . If u got the moolah, try sales@netwebindia.com for the Corsair Hydrocool System. Last time I asked, it was 20 k inclsv of taxes and freight ! Diff is, mine was a kit and the Corsair is self contained.
U think U know better...???
Naga is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/7681-water-cooling.html
Gulbir Bhatia - Pipl Profiles This thread Refback 13-08-2010 03:33 PM
