Old 27-12-2007, 06:07 PM   #1 (permalink)
hansraj's Avatar
Default unable to connect 192.168.1.1
guys i hve been told that to access the default settings of my bsnl broadband WA3002G4 modem i have to type 192.168.1.1. But iam unable to connect to this id
1. i have been trying this on my IE 7
2. I have checked with internet connected and disconnected.
3. i have already checked the Default gateway by means of
(i) Properties of my lan icon on the sys tray
(ii) On the command prompt , using the command of ipconfig
4. i have also disabled the firewall
5. i have also reduced the IE security setting to minimum
6. Pinging 192.168.1.1 does not yeild any reply when iam offline though when connected to net it does gets reply.
Now can anyone suggest me how to reach my modem settings?
Windows XP SP2 is the platform and i have mannualy configured ip address to access my desktop n laptop thru the modem as well (PC ip address 192.168.0.15 and laptop is 192.168.0.158 )
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 29-12-2007, 04:53 PM   #2 (permalink)
gowtham's Avatar
Default Re: unable to connect 192.168.1.1
I beleive the pc addresss should be in the range of 192.168.1.xx try it once.
There is always a better way to do it. Go find it!
Thomas Alava Edison
gowtham is offline
Old 30-12-2007, 10:09 PM   #3 (permalink)
hansraj's Avatar
thanks.... i realised it yesterday that the guy who came on the first day to set up the network config used 192.168.0.xx for my laptop and desktop. Now when i changed it to 192.162.1.xx i could access the modem config page
hansraj is offline
Unable to Connect to SQL Server part_time_ch QnA (read only) 2 24-08-2007 12:20 PM
Unable to connect gmail and yahoomail gjohnpaull Internet & WWW 1 16-02-2007 01:08 PM
Unable to connect Dvd rom and Dvd writer together. tango_cash Hardware Q&A 2 04-07-2006 08:19 PM
Unable to connect to router vikramk Hardware Q&A 2 08-02-2006 05:17 PM
Unable to connect broadband,win 98 Curious Guest Broadband and DTH 4 21-05-2005 11:44 AM
