can i connect an additional Control voltage transformer(CVT) or any voltage stabilizer to my APC Back UPS, because in my home voltage is sometimes high and the UPS won't turn on in regular mode.
If i try to do so then it turns on in backup mode only i.e. it runs on its battery which is limited to 10 to 15 min only.
please suggest me, if I could attach an additional CVT or voltage stabilizer with the APC ups and whether it is compatible and safe with APC ?
is using such a combination safe for my computer peripherals ? if yes then could you specify the CVT model which is compatible.
please help me..
am using the Back-UPS ES 500 (BE500y-IN) model
thanks in advance
