Old 22-08-2004, 12:05 AM   #1 (permalink)
Default Long BIOS beeps
I have a PC in a NETWORK which is beeping long countinuos beeps , its an AWARD BIOS can anybody tell for what is this beep code for, i had searched internet but can't find any long countinuos beep code.
and yes i don't think this one is for RAM.
Deepesh Agarwal,
http://www.freeware-alternative.uni.cc/
Visit website for Award-Wining Freeware\'s
deepesh83 is offline
Old 22-08-2004, 10:23 AM   #2 (permalink)
Is your monitor and graphics connected properly???
NOT Logged out for ever (well certainly)
BONZI is offline
Old 22-08-2004, 06:49 PM   #3 (permalink)
Yes they are I checked using another monitor, and can't check the card as its onboard.
Deepesh Agarwal,
Old 22-08-2004, 07:44 PM   #4 (permalink)
NikhilVerma's Avatar
Your RAM as a problem eiter it is corrupt or not installed properly...
This kind of situation only arises when you ave faulty hardware...
NikhilVerma is offline
Old 23-08-2004, 03:25 AM   #5 (permalink)
Check this out for Bios errors http://forums.tech-arena.com/showthr...ght=bios+beeps
Yours seem to suggest RAM error.
U think U know better...???
Naga is offline
Old 23-08-2004, 08:59 AM   #6 (permalink)
Default Thanks
Thanks will have a look at it.
Deepesh Agarwal,
Old 23-08-2004, 02:30 PM   #7 (permalink)
Default ok
checked but now the RAM is ok and beeps are gone but still computer is unbootable the PC's green light is on fans r runing. but nothing comes up on monitor(alreday tried different monitor).
Deepesh Agarwal,
Old 23-08-2004, 06:25 PM   #8 (permalink)
can u atleast see the post on ur screen ???
No Mercy, No Limits.
theraven is offline
Old 24-08-2004, 09:35 AM   #9 (permalink)
what does that mean ?????????????????
Deepesh Agarwal,
Old 24-08-2004, 10:50 AM   #10 (permalink)
what does that means theraven?
and for u deepesh just try to boot ur system after replacing RAM cause Long beeps arise on RAM eror
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 24-08-2004, 10:00 PM   #11 (permalink)
checked RAM is fine.
Deepesh Agarwal,
Old 24-08-2004, 10:57 PM   #12 (permalink)
post=POST=P.O.S.T.= Power On Self Test=where ur system checks the amt of ram and the drives installed ... where u can press "del" to get into setup !
theraven is offline
Old 24-08-2004, 11:08 PM   #13 (permalink)
the error u stated occurs becos of faulty h/w ( generally becos of improperly installed RAM or Faulty Ram).. However it mght also occur becos of ur monitor ( which mght hav gone faulty )
However u hav checked both ...
So now onwards to next question
WHAT is POST? (POWER - ON Supply Test)
well do u remember the screen where ur HDD's and CD-R/RW's and DVD-R's/RW's are recognizes,
The screen where u get the AWARD Logo and the imeediate next screen where ur system components are listed
welll do you see those screens
well if u dont see these stop doin anything urself and get a professional to do the job
if u see thses screens and the comp hangs up while loading windows, then windows may hav gone corrupt,
also, even windows mght load but no monitor display then " DID U INSTALL ANY LATEST GARPHICS DRIVER OR DIREXT X VERSIONS)
If u did then the software mght be faulty, in such a case ( if using win 98 )boot using a floppy and do a complete format of the partition where win98 is loaded
if using winxp press f8 while boot up process , select option " boot using last known good config.. "
Welll hope this solves ur problems
Attack life, it\'s going to kill you anyway.
walking-techie is offline
Old 24-08-2004, 11:38 PM   #14 (permalink)
Thanks i will get a prof. for this one, but can u suggest why three of my comp. in a network boot about 2-3 hours late and shows checksum error (battery already checked and replaced), this happened after i closed the PC's for about 2 months.
Deepesh Agarwal,
Old 25-08-2004, 06:14 AM   #15 (permalink)
It maybe a faulty memory module , what my experience says is that normally due to a loose agp card , in ur case its onboard so its irrerevant. Check and try to update the BIOS.
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK
indro is offline
Old 25-08-2004, 05:25 PM   #16 (permalink)
ok what about the late botting computers.
Deepesh Agarwal,
Old 25-08-2004, 05:29 PM   #17 (permalink)
OK but what about long booting problem.
Deepesh Agarwal,
