Old 25-12-2007, 09:45 PM   #1 (permalink)
GONNA GET ALL OF YOU
JohnephSi's Avatar
Default Hard disk
Hi guys iam planning 2 buy a hard disk of 80 GB or 120 GB for my budget of Rs 3000. Plz tell me the best option for it . Plz relll me how 2 my current hard disk whrthr is it sata or ata . Iam a newbie abt this
JohnephSi is offline
Old 25-12-2007, 09:51 PM   #2 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Default Re: Hard disk
go for segate 320gb cost rs 3500/-
which is ur mobo?
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 25-12-2007, 09:59 PM   #3 (permalink)
JohnephSi's Avatar
Is it sata or pata.Plz rell me how 2 my current hard disk whrthr is it sata or pata . Iam a newbie abt this
Old 25-12-2007, 10:08 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
If U are using this cable to connect ur hard disk ..than it is PATA.
And if U are using this cable to connect ur hard disk , than it is SATA:
ravi_9793 is offline
Old 25-12-2007, 10:11 PM   #5 (permalink)
CG Artist
gaurav_indian's Avatar
You can get at least 250gb hdd within 3000 Rs.
gaurav_indian is offline
Old 25-12-2007, 10:15 PM   #6 (permalink)
JohnephSi's Avatar
Is there any issue 4 compatibility of the hard disk with the motherboard
Is there any issue 4 da noncompatibility of the hard disk with the motherboard
Old 25-12-2007, 10:15 PM   #7 (permalink)
CG Artist
yes.Which motherboard do u have?
Old 25-12-2007, 10:35 PM   #8 (permalink)
JohnephSi's Avatar
VIA mother board . It is 2 yrs old
I hope it is pata from the above pictures
Old 25-12-2007, 10:36 PM   #9 (permalink)
its pata...go for segate 250 GB pata harddisk costs around 3k
I m nt th bst...bt i m nt lik th rst
thepirateboy is offline
Old 25-12-2007, 11:08 PM   #10 (permalink)
JohnephSi's Avatar
How can i check 4 compatibility with my motherboard
Old 25-12-2007, 11:16 PM   #11 (permalink)
dOm1naTOr's Avatar
Surelly every mobo 2 yrs old support pata HDDs. U can get a 250Gb pata HDD from Segate, Hitachi etc for some 2.5~2.7k.
No more to think bout compatibility. u can go for it.
How are u able to double post???for me itll always merge within 1min
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 25-12-2007, 11:50 PM   #12 (permalink)
JohnephSi's Avatar
When i talk with1 of our computer store they told me that 80 gb cost arnd 2.5k .How come this 1. It means that any hard disk space will b compatible with any motherboard
Old 26-12-2007, 12:25 AM   #13 (permalink)
CG Artist
You have a nice way of bumping thread.Post the same thing twice.
Old 26-12-2007, 12:29 AM   #14 (permalink)
JohnephSi's Avatar
Plz help me out i ve 2 buy 2day
Old 26-12-2007, 12:30 AM   #15 (permalink)
CG Artist
Where do u live?And buy 250gb pata.It comes in your budget.
Old 26-12-2007, 12:31 AM   #16 (permalink)
JohnephSi's Avatar
I live in Manipur. Will any pata hard disk b compatible with any motherboard
Old 26-12-2007, 12:34 AM   #17 (permalink)
CG Artist
Yes lol.Newer motherboards doesnt support pata as far as i know.But your motherboard is 2 years older.So no problem.
Old 26-12-2007, 12:47 AM   #18 (permalink)
JohnephSi's Avatar
Which one is costlier pata or sata
Which brand is the best
Is it needed that the new hdd shud b of 7200 rpm sinilar with the previous 1
Old 26-12-2007, 12:56 AM   #19 (permalink)
CG Artist
i think he is fooling you.
You can go for seagate,wester digital,hitachi.I will prefer Wester Digital.And yes go for 7200 RPM.
Old 26-12-2007, 12:58 AM   #20 (permalink)
meowww meoww
Kenshin's Avatar
HEy...i also wanna ask one ques on harddisk....I hv 915 board so its SATA....can I buy a SATA2 drive and install....I think it will work at sata speeds instead of sata2...Is it true ..
"Microsoft: You've got questions. We've got a dancing paperclip."
Have fun,no worries..
Kenshin is offline
Old 26-12-2007, 12:59 AM   #21 (permalink)
JohnephSi's Avatar
@gaurav_indian Hu is fooling me
Old 26-12-2007, 01:02 AM   #22 (permalink)
CG Artist
your shopkeeper.You can get 200 gb in 2500 rs.
Old 26-12-2007, 01:11 AM   #23 (permalink)
JohnephSi's Avatar
Ok i wil ask 2 oder shops 2 . I havent bought it yet. 4 Which cmpany did u get 200gb 4 rs 2500
Old 26-12-2007, 01:17 AM   #24 (permalink)
CG Artist
Seagate.
Old 26-12-2007, 08:28 AM   #25 (permalink)
JohnephSi's Avatar
Plz tel me da model no.
Is it Seagate ST3250623A-RK
Old 26-12-2007, 09:37 AM   #26 (permalink)
JohnephSi's Avatar
Old 26-12-2007, 02:28 PM   #27 (permalink)
JohnephSi's Avatar
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
RAW hard disk sweetricha07 Hardware Q&A 1 04-11-2006 09:27 PM
how to add two hard disk ravi_9793 QnA (read only) 3 23-07-2006 06:53 AM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
