Old 25-12-2007, 06:50 PM   #1 (permalink)
Default Unable to click Start Button and Task bar
Every time I start my computer I get a message window as under:
Windows Explorer has encountered a problem and needs to close. We are sorry for the inconvenience. I again and again pop ups after closing it. As such I am unable to work. Also my Start Button and Task bar always showing dumb bell. So unable to click Start Button and Task Bar. I have to shut down my computer by Ctrl+Alt+Del. Any suggestions/Help. (PS.: I do not want to reformat my windows as I do not have CD of my MoBo and Every time after reformating I have to install drivers manually and I do not have driver of my sound card. )
http://www.arunshakya.blogspot.com
Arun Kumar is offline
Old 25-12-2007, 07:18 PM   #2 (permalink)
a_tif's Avatar
Default Re: Unable to click Start Button and Task bar
press ctrl+alt+del to get task manager
File->New task
type sfc /scannow
windows cd is required for verifying dll files
if ur dll have changed it will restore them from the windows cd
this might solve ur problem
a_tif is offline
Old 25-12-2007, 08:48 PM   #3 (permalink)
a_tif: Sorry, It couldn't work. I got message "windows cannot find 'sfc/scannow'. Make sure you typed the name correcty, and then try again. To search for a file, click the Start button, and then click Search.
Old 26-12-2007, 12:46 PM   #4 (permalink)
a_tif's Avatar
if u can open command prompt from task manager
new task-> type cmd
type sfc /scannow in command prompt
a_tif is offline
Old 26-12-2007, 07:24 PM   #5 (permalink)
hullap's Avatar
post your hijackthis log
hullap is offline
Old 26-12-2007, 10:57 PM   #6 (permalink)
Thumbs up Re: Unable to click Start Button and Task bar
a_tif: Thanks a lot!!! Its solved. Once again thanks for help.
Old 26-12-2007, 11:53 PM   #7 (permalink)
a_tif's Avatar
Glad to help
MODS pls Close the thread
a_tif is offline
start button right click options Shasta Software Q&A 4 29-01-2007 10:03 PM
I Want To Change My START Button! DAVIS QnA (read only) 1 13-02-2006 10:08 AM
Playing with the 'Start' menu button Apollo QnA (read only) 3 05-04-2005 07:25 PM
XP START BUTTON ashok Software Q&A 2 15-01-2005 02:47 PM
