Old 24-12-2007, 10:56 PM   #1 (permalink)
gowtham's Avatar
Smile Lot of questions!
1)I have decided to get myself a phone this new year. My maximum budget is 25-30k. My pain use would be browsing the net, so my main priorities are- screen and performance. I think the iphone would suit me nicely. any other viable alternatives pls?
2)Is calling regular phones from voip possible? what is the simplest way?
3)Suggest me a provider with EDGE services and unlimited net usage in india.
Thanks in advance!
There is always a better way to do it. Go find it!
Thomas Alava Edison
gowtham is offline
Old 24-12-2007, 11:57 PM   #2 (permalink)
Default Re: Lot of questions!
get N95, install Truphone for VOIP.
Ravirdv is offline
Old 25-12-2007, 12:01 AM   #3 (permalink)
gowtham's Avatar
my concern is the screen size and the ipohne has the larget screen for a phone i believe?
Thomas Alava Edison
gowtham is offline
Old 25-12-2007, 12:18 AM   #4 (permalink)
Google Bot
Pathik's Avatar
Ur options wd be iphone.
And n95 8gb,n82..
Also the e61i is great..
But the safari browser on the iphone pawns all else
Pathik is offline
Old 25-12-2007, 03:45 AM   #5 (permalink)
hailgautam's Avatar
I am using e61i and with it's qwerty kb and large screen it is THE machine for browsing. Airtel has the unlimited plans with edge. I have this rs. 500 p.m. plan in Hyderabad.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 25-12-2007, 12:31 PM   #6 (permalink)
gowtham's Avatar
how about the voip thing?
Thomas Alava Edison
gowtham is offline
Old 25-12-2007, 02:57 PM   #7 (permalink)
gowtham's Avatar
keep the responses coming in pls!!
Thomas Alava Edison
gowtham is offline
Old 25-12-2007, 07:04 PM   #8 (permalink)
gowtham's Avatar
i knew that. what i wanted to know is that can i call regular phones from the iphone, using VOIP from its web capabilities?
Thomas Alava Edison
gowtham is offline
Old 26-12-2007, 01:32 PM   #9 (permalink)
gowtham's Avatar
come on guys. please help me out. i only have a week left to deicde!!!
Thomas Alava Edison
gowtham is offline
Old 26-12-2007, 01:35 PM   #10 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
well, I think you can do those things in iPhone, once its firmware is updated.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 26-12-2007, 03:10 PM   #11 (permalink)
AJJU
azzu's Avatar
ill Better suggest u the N95
u can do much moore with the Symbian Platform
I love and Live to Design
azzu is offline
Old 26-12-2007, 05:27 PM   #12 (permalink)
gowtham's Avatar
so what about the network? which one should i go for??
Thomas Alava Edison
gowtham is offline
Old 26-12-2007, 05:49 PM   #13 (permalink)
AJJU
azzu's Avatar
Undoubtedly AIRTEL if u want UL net.
azzu is offline
Old 27-12-2007, 11:57 AM   #14 (permalink)
gowtham's Avatar
does airtel support EDGE? i have been through its site, but havent been able to find anything. whats the tariff btw? any existing users here?
Thomas Alava Edison
gowtham is offline
Old 27-12-2007, 12:01 PM   #15 (permalink)
AJJU
azzu's Avatar
it Does support Edge if u have a Edge enable tower near u
i dont know wheatther there r EDGE towers in VIJWADA
presently iam on 15/- rupees UL 24 hoours plan
its good
azzu is offline
Old 27-12-2007, 12:08 PM   #16 (permalink)
gowtham's Avatar
how to find out if there r edge towers in my area? and anyways which are r u from?
Thomas Alava Edison
gowtham is offline
Old 27-12-2007, 12:31 PM   #17 (permalink)
AJJU
azzu's Avatar
^ tough
but if u hav a Edge enabled mobile and ur active on MO the status in mobile will show "E" rather than "G"
Btw: iam from ELURU
azzu is offline
Old 27-12-2007, 04:22 PM   #18 (permalink)
gowtham's Avatar
cool. maybe we can meet up sometime
do u have edge in eluru"?
Thomas Alava Edison
gowtham is offline
Old 27-12-2007, 06:49 PM   #19 (permalink)
AJJU
azzu's Avatar
^ Nope yaaar
do u cum to ElUru ??
i mean ....u hav some one here?
azzu is offline
Old 10-01-2008, 03:21 PM   #20 (permalink)
Asterisk enthusiast
abhasbajpai's Avatar
for voip there are many softwares for every wifi phone for gprs there are some like fring, there are other's also, now to connect to pstn with voip you need a pstn gateway, like you can use skype or other services like that.
if you want to use VoiP please let me know the phone and usage pattern, i will then suggest you some services.
abhasbajpai is offline
Old 11-01-2008, 03:24 AM   #21 (permalink)
hailgautam's Avatar
now a days i am using fring on the e61i, i even called a friend in prague using the gtalk, it worked. but the thing is that the connection was not good so was not a great expreiance, fring also allows you to use skype,
does any one has idea if airtel could reduce the bandwith used by a mobile phone. the first few days i used to get upto 20kbps on the phone while downloading some torrents (axxo movies) now i am hardly touching 10 and that too for a few sec far in between, though the torrent is not well supported i am getting slow speeds in usual inter net browsing as well.
i wonder what could be the reason...
Where you going?
With Luck forward.
Old 12-01-2008, 08:24 AM   #22 (permalink)
Asterisk enthusiast
yes there is a problem as of now with fring and gtalk,yahoo even on wifi, i think this may be due to connectivity between servers for Google/yahoo and fring.
but when you use it between fring to fring or fring to sip it is working excellent.
Some Questions Sparsh007 QnA (read only) 4 12-06-2007 09:32 PM
I have few questions!!!!!!!!!!!!!! sushantsaurabh QnA (read only) 4 17-05-2007 11:26 AM
Questions...lots of questions... Arachnid Open Source 16 15-06-2005 12:05 PM
some HDD and RAM questions..... saiko QnA (read only) 16 29-03-2005 10:50 AM
