24-12-2007, 06:59 PM
need a bluetooth dongle
i want to buy a bluetooth dongle but they are available from 300 to 1500bucks. what things i need to consider before buying it?
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
24-12-2007, 07:04 PM
Stay Silent!
Re: need a bluetooth dongle
nuthin much dude.. just get any BT dongle- provided tht u need it fr basic cellphone transfers
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
24-12-2007, 07:08 PM
Google Bot
Get a standard BT dongle for around 150 bucks.. it ll come wit bluesoliel or widcomm driver.. plug it and use..
24-12-2007, 07:10 PM
Stay Silent!
^^ does it have a multi channel support???
I saw me running,
25-12-2007, 10:04 PM
shd i go and buy any one of them available....
25-12-2007, 10:28 PM
Rebooting
No... Make sure it is Blutooth 2.0 wish supports 3 MBPS... and if you are one windows user make sure it iether supports Vista default Bluetooth adopter driver...
or it should bags it own full version Vista drivers...
do note, that, PC Suite or such softwares wont support many driver providers for the bluetooth adopter...
ex, bluesoleil.com drivers are not supported by Nokia PC Suite
rebooting
ChotoCheeta.com
25-12-2007, 10:30 PM
I am thinking of one with these features:
ORCHID BLUETOOTH DONGLE
# Specifications : Bluetooth V2.0 and EDR
# Bluetooth class 1 : 500 meters (in open space)
# Carrier frequency : 2.4 to 2.483GHz
# Data rate : up to 3Mbps
# Frequency hopping spread spectrum
# GFSK (1Mbps), D/4-DOPSK (2Mbps), 8DPSK (3Mbps)
# USB version 2.0, DV 5V (USB power)
# Sensitivity : 82dBm (typical), GFSK
# RF output power : 20dBm (typical), GFSK
# Supports Windows XP, 2000, ME and 98SE
# LED indicators.
This in Rs.250 bucks (Indiatimes Shopping) + 50bucks for courier charges making a total of Rs.300 bucks.
I just need it for connecting cell phone to access net on pc and file transfers. Is this fine or i shd go out and buy from local stores. What you ppl say? Pl reply asap.
26-12-2007, 09:39 AM
luk out for vista compatibility n version.......
26-12-2007, 12:20 PM
Stay Silent!
i find it a bit too expensive online..
try a local seller buddy
I saw me running,
31-12-2007, 02:33 AM
got myself a dongle....
do i need to select "recieve a file" everytime when i wish to send a file from my cell to PC? or is there any work out?
31-12-2007, 05:36 AM
bluesoleil fully supports Nokia PC Suite provided you are using updated version of both.
31-12-2007, 09:15 AM
Stay Silent!
Well no, if u hav a nokia [ i kno only abt nokia, pardon me] u hav an option to "Authorise a device". Use that, simple
I saw me running,
31-12-2007, 01:01 PM
hey hey hey
i got myself a dongle for 200bucks, yes it is bluetooth 2.0
vendor said it supports vista but it is not written on the packaging. moreover it gets detected in WIN XP automatically...no need of installing its own drivers
@enticer86
I have already done that.. I want to know if there is a way by which i can authorize connection for my PC cuz i need to select "Receive a file" every time i need to receive a file on comp. moreover multiple files cant be send, only one file at a time.
31-12-2007, 01:29 PM
Stay Silent!
yeah.. the same thing works the other way too
I gues u need to connect ur cell, and PAIR it, and AUTHORISE it as well
thats abt it if m not wr0ng...
Cheers
I saw me running,
31-12-2007, 01:43 PM
Cheers
i mean to say Authorise connection on my Pc
31-12-2007, 01:45 PM
Pair it one time & set on phone tick the option 'set as authorized'.Now the connection will take place without any prompts.This is for nokia phones only.
31-12-2007, 01:52 PM
Google Bot
Yep use the drivers and pair it with a key and tick "Accept connection requests automatically."
31-12-2007, 04:52 PM
Stay Silent!
^ +1 fr u
I saw me running,
31-12-2007, 08:18 PM
#19 (permalink)
why you all guys not getting it? I have already set the pairing as authorize on cell. If i am sending a file from PC to cell, it doesn't prompt for accepting the file. ok.
the same i want to do with PC so that when i send file from my cell, it gets accepted automatically, unlike manually selecting "Receive a file" I hope m clear now...
31-12-2007, 09:17 PM
#20 (permalink)
Stay Silent!
d00d we are telling u the same thing... to authorise ur cell so that ur PC bonds with it
I saw me running,
Search this Thread |
