Old 30-03-2005, 05:48 AM   #1 (permalink)
Fresh Stock Since 2005
Default What programs do you use for security
What programs do you use for security of your computer. Here's a list of apps that I use.........
On one of my computers:
ZoneAlarm Security Suite
Winpatrol (freeware)
Ad-Aware SE (freeware)
All critical updates
On another computer:
Norton Antivirus 2005
Winpatrol
Kerio Personel Firewall
Ad-Aware SE
khattam_ is offline
Old 30-03-2005, 12:21 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Well i use AVAST ! ANTI VIRUS HOME EDTION given in the DIGIT MARCH 2005 CD issue.
well it does a preety good job and cleans thoroughly.
But plz suggest me sum other softwares as i will be getting the MTNL's so called BROADBAND seva known as TRI-BAND so i will be needing sum softwares installed on my PC to keep away from viruses,trojans,spy wares and also needing a firewall to keep my PC safe from hackin or deleting my files.
Is it recommendable to use softwares of gifferent companies on the same PC like a combination of AVAST! ANTIVIRUS HOME EDITIONa nd NORTON FIREWALL/INTERNET SECURITY??
plz suggest....
cheers n peace....
ashu888ashu888 is offline
Old 30-03-2005, 01:54 PM   #3 (permalink)
I use none of this softwares . format the pc when i got some trouble . its the easiest and dont kill too much of time with a slow pc.
on another pc :
i use linux. all the important files on it.not connected to the net, no cd rom and a sealed floppy drive
but i need a good efficiet anti virus too ... which dosent slow down the pc and does a quick scan .... can some one help ?
vijaythefool is offline
Old 30-03-2005, 02:30 PM   #4 (permalink)
club_pranay's Avatar
SP2 + Norton2004 + Spybot S&D + Lavasoft AdWare + XsoftSpy for me
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 30-03-2005, 03:30 PM   #5 (permalink)
tuxfan's Avatar
I use Linux. Thats the best security software
Under Windows, I use ZoneAlarm, Norton Antivirus, Spybot S&D and try to avoid using all Microsoft products.
tuxfan is offline
Old 30-03-2005, 04:06 PM   #6 (permalink)
i use SP2 + All Updates + Norton 2005 + Zone Alarm Pro + Adaware
Shwetanshu Srivastava
shwetanshu is offline
Old 30-03-2005, 04:19 PM   #7 (permalink)
whoopy_whale's Avatar
Norton Antivirus+ Ad Aware
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 30-03-2005, 06:32 PM   #8 (permalink)
`http://www.thinkdigit.com/forum/viewtopic.php?t=13846
plz refer to that thread
No Mercy, No Limits.
theraven is offline
