Old 22-12-2007, 01:05 AM   #1 (permalink)
hmmmmmmmmmmmmm's Avatar
Default TaskManager Automatic Exits In 5 Seconds ??
Even folder option too ???
wht to do ?
Sellin Rapidshare Account 30 Days Validity for 6 $ PM ME
hmmmmmmmmmmmmm is offline
Old 22-12-2007, 01:09 AM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: TaskManager Automatic Exits In 5 Seconds ??
Post your Hijackthis log file contents.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 22-12-2007, 07:56 AM   #3 (permalink)
Wise Old Crow
blueshift's Avatar
You have been infected by a virus...most prabably a Ronrok or Delf virus.
Do you use any antivirus?
http://twitter.com/blueshift155
blueshift is offline
Old 22-12-2007, 01:35 PM   #4 (permalink)
evewin89's Avatar
ya blueshift is rite, u have been infected by a virus may be (win32) use AVAST or any other ANTI-VIRUS program.
Evil Lives 4ever......
evewin89 is offline
Old 22-12-2007, 01:43 PM   #5 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
You have been that virus which makes NEW FOLDER at each locations
Symptoms
1. No Taskmanager
2. No Command Prompt
3. No Regedit
Download and ry this
http://www.mediafire.com/?du5m2kwzmeg
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 22-12-2007, 05:12 PM   #6 (permalink)
Wise Old Crow
blueshift's Avatar
I was infected by both the viruses. I had used Avast antivirus to remove it.
Also check this thread below.
No run, No taskmanager ??????
Old 23-12-2007, 11:51 AM   #7 (permalink)
This is definitely a Virus. Use NOD32 or Kaspersky 7 trial.
ico is offline
Old 23-12-2007, 03:51 PM   #8 (permalink)
The Frozen Nova
casanova's Avatar
Go to command prompt and try using the command
cd c:\NTDETEC1
If you can enter this directory, then try this link
www.nerdweed.blogspot.com
casanova is offline
Old 25-12-2007, 05:48 PM   #9 (permalink)
Distinguished Member
anandk's Avatar
hmmmmm ... get your hijackthis log auto-analysed at www.hijackthis.de
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Google exits Digg, enter Microsoft! anandk Technology News 5 28-07-2007 09:30 PM
No run, No taskmanager ?????? jayanbhm QnA (read only) 4 07-06-2007 08:07 PM
Game automatically Exits --- NFS_Most_Wanted ajayshuchi Gamerz 9 02-10-2006 12:31 PM
my taskmanager! legolas QnA (read only) 8 30-12-2005 01:49 PM
