Old 21-12-2007, 07:27 PM   #1 (permalink)
User Name's Avatar
Default DVD Cleaning?
I have some scratched DVDs.
Do any one know how to remove it(any liquid cleaner).?
User Name is offline
Old 21-12-2007, 07:34 PM   #2 (permalink)
j1n M@tt's Avatar
Cool Re: DVD Cleaning?
I usally does with hand washing soap........
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 21-12-2007, 07:44 PM   #3 (permalink)
User Name's Avatar
Default Re: DVD Cleaning?
which soap?
Do anyone know CD/DVD analyzing software which shows bad sector in CD/DVDs
Old 21-12-2007, 07:46 PM   #4 (permalink)
j1n M@tt's Avatar
Talking Re: DVD Cleaning?
hey man, just take any wet smooth cloth(only lightly wet,ok),apply a small amount soap(take any bathing soap u like..... )
j1n M@tt is offline
Old 21-12-2007, 07:49 PM   #5 (permalink)
User Name's Avatar
i don't think they will remove scratches. Any strong liquid which remove small layer of plastic coating
Old 21-12-2007, 11:29 PM   #6 (permalink)
j1n M@tt's Avatar
yeah,its right...they don't remove scratches,but only cleans
j1n M@tt is offline
Old 22-12-2007, 09:55 AM   #7 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
If your scratches are very bad, it is useless to try things. If it is moderate, you can try using toothpaste. Take a clean, soft lint-free cloth and moisten it, using the cloth wrapped around one of your finger. Then apply a minute quantity of toothpaste on the cloth and wipe radially on the DVD. Don't apply too much pressure, else you will be scratching the disc more! Then, clean the DVD using just water using the same cloth, but make sure it is clean and no toothpaste. Worked a lot of times for me. I used to do this when I got scratched discs from the movie rental store
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Cleaning Fan Mohak QnA (read only) 1 12-11-2007 12:15 AM
CPU Cleaning Charan Hardware Q&A 18 17-10-2007 12:52 PM
Screen Cleaning??? wwwescape Mobiles and Tablets 5 27-06-2007 02:21 PM
Cleaning LCD screen? harpoon TVs / Monitors 14 14-11-2006 12:34 AM
DVD rom cleaning speedyguy Hardware Q&A 11 11-06-2006 04:18 PM
