Old 21-12-2007, 06:45 PM   #1 (permalink)
evewin89's Avatar
Default DVD REGION problem?
i have a SONY DVD ROM (DDU1615) & its CURRENT REGION is showing "NOT SELECTED" i have 5 changes remaining..... i want 2 know what region should i select 2 get the best from my DVD ROM...
Evil Lives 4ever......
evewin89 is offline
Old 21-12-2007, 07:57 PM   #2 (permalink)
User Name's Avatar
Default Re: DVD REGION problem?
keep it "NOT SELECTED".
User Name is offline
Old 21-12-2007, 08:06 PM   #3 (permalink)
bharat_r's Avatar
if u want to play dvds of other other regions, just use AnyDVD. You needen't have to change any setting of ur dvd rom.
bharat_r is offline
Old 21-12-2007, 09:00 PM   #4 (permalink)
evewin89's Avatar
THANKZ 4 ur valuable comments....
evewin89 is offline
Old 21-12-2007, 09:05 PM   #5 (permalink)
left this forum longback
praka123's Avatar
Smile Re: DVD REGION problem?
google for Content Scrambling System(CSS) and dvdcss
praka123 is offline
Old 22-12-2007, 09:19 AM   #6 (permalink)
Attitude matters
Ponmayilal's Avatar
DVD region and CSS are two seperate identities.
DVD region coding which effectively prevents DVDs from one region being played in DVD players of other regions is set in the players , be it hardware or software ..
CSS is the copy protection mechanism by which you are effectively prevented from copying the DVD and is built into the DVD media.
Making the DVD player region free by flashing the appropriate firmware - either legitimate or hacked - does not guarantee that all DVDs can be copied.
In India, copying the DVDs owned by one , is permissible either as a back up or for playing on in one's own computer as "fair use" ( as per my understanding)
It is only when you want to rip the DVDs for "fair" use, one should look in for the appropriate software that will defeat the copy protection built-in in the DVDs.
Ponmayilal is offline
Old 22-12-2007, 01:27 PM   #7 (permalink)
evewin89's Avatar
thankz 4 the info. Ponmayilal
evewin89 is offline
DVD region coding digit_rajesh QnA (read only) 4 14-02-2007 07:12 PM
DVD Region patkim Hardware Q&A 1 26-11-2006 11:30 PM
DVD Region Code bhoolkumehul QnA (read only) 9 02-11-2006 01:11 AM
DVD Region Codes dmmomaya QnA (read only) 2 04-09-2006 05:19 AM
DVD Region Bruce_Wayne Hardware Q&A 8 22-03-2006 06:50 PM
